10-30-2019
05:17
06:04
JuanJoFitbit
10-30-2019
05:17
06:04
JuanJoFitbit
I cannot seem to get the body fat to work in the app with my scale. I've set it up and it is taking weights but it always shows the same percentage body fat. I am standing on it Barefoot. Any suggestions?
Moderator edit: updated label
10-30-2019 08:23
10-30-2019 08:23
Aria Air does not measure body fat %; that's one of the things that makes it cost less.
10-30-2019 08:26
10-30-2019 08:26
Sorry, I meant BMI.
10-30-2019 09:20
10-30-2019 09:20
BMI only changes when your weight changes, regardless of body fat. It depends only on height and weight. If, and only if, your weight has been changing, then BMI should also be changing. Try weighing yourself while holding something weighing a few pounds, and see if that doesn't change your BMI. You can then delete that reading from Fitbit, or just leave it, knowing it will get b ack to normal at next weigh-in.
