Aria Air care
Hi everyone,
I have an Aria Air that is located in my bathroom. Fitbit says to use a damp, soft cloth to clean it. Would glass cleaner work too? Also, what do they mean by “extreme humidity and moisture”? It’s a stupid question but I do have it in the bathroom where there is a shower.
Thanks everyone!!
2 REPLIES 2
Hi @Young_Jedi_92  you can learn more in the user manual, page 14 - click to go there. It looks like you shouldn't use glass cleaner. Maybe gentle baby wipes would work. I'm not sure what they mean, but with any product prolonged exposure to moisture or humidity might have an affect on the batteries.
Stepping in the U.S.A. since September 2013. Android 14
@Young_Jedi_92   The Aria Air is designed for a humid bathroom environment.  The environmental conditions say it will work in 90% relative humidity.  If your relative humidity is higher than that, you won't just have fog on the mirror, you'll have water droplets condensing on the walls.
I don't recommend baby wipes.  Even the free and clear, sensitive wipes have skin conditioners that will likely leave streaks.  I clean mine with a damp microfiber cloth.
Laurie | Maryland
