05-23-2022 11:16
05-23-2022 11:16
My Aria Air has started to display the exceed weight limit error “- - - -“ when I now step on it. It will track for about 15lbs then jumps to exceeding weight limit. I’ve removed and replaced the batteries with a wait in between and have it on a hard flat surface. Any suggestions on how to get it back to tracking weight? Thank you.
05-24-2022 09:48
05-24-2022 09:48
Hello @SharonWT and welcome to the Community. This is a wild guess suggestion. Store your scale on its side for a while. It will need to recalibrate itself if you do this. Aria Air manual See p 8. Please contact Support if the problem persists.
Laurie | Maryland
05-24-2022 18:14
05-24-2022 18:14
Thank you! I will give it a try (and look at the manual).
05-25-2022 21:23
05-25-2022 21:23
Hi, I tried the laying on it's side and did a full reset. Still won't calculate weight past about 15 lbs. I also notice that it hasn't synced since early April. Any other suggestions?
05-26-2022 06:27
05-26-2022 06:27
@SharonWT I recommend contacting Support for more help.
Laurie | Maryland
