11-12-2019
05:05
06:05
JuanJoFitbit
11-12-2019
05:05
06:05
JuanJoFitbit
Just a quick question regarding my new Aria Air scale. I was finally able to get it to sync with my phone and my Fitbit app. The weight comes through just fine but the body fat percentage does not populate in the body fat% field on the app.
The scale was touted as being able to calculate this, and to determine the percentages with the help of the app. I had to manually figure out my body fat percentage and add it to my app. What is the procedure for having this information filled in automatically by the scale? Have I missed a setup step in either the app or the scale?
Thanks!
11-12-2019 06:21
11-12-2019 06:21
Hello @debbert1967 and a warm welcome. I think you misunderstood the product details. The Aria Air does not calculate percent body fat.
Laurie | Maryland
11-12-2019 06:21
11-12-2019 06:21
Laurie | Maryland
11-12-2019 06:42 - edited 11-12-2019 06:43
According to the promotional email that I received prior to ordering the
Aria Air, the screen shot of Fitbit's ad clearly states "see your BMI in
the Fitbit app". I'm not sure how I could have been mistaken by the very
claim that Fitbit makes.
11-12-2019 21:02
11-12-2019 21:02
If you go to the FitBit app, and the weight tile, then swipe left, the third graph is BMI (Body Mass Index). It is a simple calculation based only on your height (which you've told the app) and weight (which the Aria Air measures). So it is in the app.
11-12-2019 23:01
11-13-2019 13:57 - edited 06-15-2020 04:40
@debbert1967 MANY users confuse BMI with percent body fat. Like @KLSeattle said, BMI is a calculation based on height and weight. The Aria/Aria 2 use electrical bioimpedance to estimate percent body fat. The Aria Air does not measure percent body fat.
Laurie | Maryland
11-15-2019 02:59
11-15-2019 02:59
The display does have a bit that says BMI height and wait above the weight display. Obviously they don't light up though. What are they for?
12-31-2019 05:03
12-31-2019 05:03
I am so disappointed with these scales. My son purchased them as a Christmas Gift, they cost him £50, he is a student, so this is not a small amount to him. My cheaper Salter scales are able to tell me weight, BMI, Water content, Fat %. If these scales had not been a gift I would be returning them. Waste of time product from Fitbit.
01-20-2020
06:55
05:00
JuanJoFitbit
01-20-2020
06:55
05:00
JuanJoFitbit
I bought this scale because of a promotion - fully expecting BMI to be sensed. I see this post is old - after all this time, your marketing is still off. That said, I'm trying to use the scale for the first time and the weight in the app and on the scale do not match.... I took out the batteries and put them back in the scale. I saw the bit about completely restarting the scale - you've got to be kidding me!.
I stepped on it again and it sent the correct weight to the app. Really disappointed about the % body fat. Wish the app would not automatically populate 25% - it sort of rubs it in
Moderator edit: merged reply
01-20-2020 11:40
01-20-2020 11:40
Hello @cal77447 and a warm welcome. I read both your posts and I have some thoughts for you. I am assuming that you are the only user on your scale and that any weight will go to your account. A weight doesn't sync to your account until you accept it. The scale doesn't know who is on the scale until a weight is accepted. Imagine this -- let's say there is some maintenance person working on your plumbing. This person decides to step on your scale. Hey, no one is looking, right? Should this be on your account? Since the scale doesn't know who is on the scale, the BMI displays in the app after it is accepted.
Also You put 25% in your post. Many people confuse BMI and % body fat. The Aria Air does not measure % body fat. It calculates BMI, a relationship between height and weight. BMI doesn't take body build into account. A very fit, muscular person can have a BMI over 25, yet not be fat.
Laurie | Maryland
02-06-2020
21:28
05:04
JuanJoFitbit
02-06-2020
21:28
05:04
JuanJoFitbit
Where is BMI info displayed in the app?
I found it.
02-09-2020 09:46 - edited 02-09-2020 10:41
Finally someone mentions something about BMI results and muscular people. I am 5’7”. I weigh 194 lbs. My BMI is 30.6, which means that I am obese, but my 33-inch waist tells me I am not obese. My weight is mostly muscles. I think BMI was developed at a time when going to the gym and fitness was not considered important. If Fitbit had existed back then, no one would have cared. But people do care about their fitness now, and Fitbit should create a BMI setting for muscular people—an on/off switch of some sort that recalculates the BMI, based on more parameters than just the weight-height ratio of an individual.
02-09-2020 12:47
02-09-2020 12:47
I’ve tried removing the batteries multiple times followed by weighing 5 times , yet the body fat measurement is inconsistent. Please assist
02-27-2020 12:40
02-27-2020 12:40
Yes, Thank you so much! I’ve had the same struggle ever since I got my scale and could not figure out what I was doing wrong.
Best Answer05-14-2020 06:46
05-14-2020 06:46
Female here and out stats about the same I'm about 5lbs under you. BMI is so pointless to me all I ever want to know is BFP and lean mass. My WW scale offers better info. Glad I got this on sale....I guess...
05-26-2020 11:34
05-26-2020 11:34
I just got my scale and on the screen it has ft, in, percent, kg, lb, BMI, WiFi, and there are some arrows... what are those for if the scale doesn’t track that?
05-26-2020 14:38
05-26-2020 14:38
If it has WiFi, then it is not an Aria Air, but the Aria model.
Best Answer06-15-2020 04:29 - edited 06-15-2020 04:33
I wish there was an answer from Fitbit for this question.. any question. I'm new to the community.
07-20-2020 16:55
07-20-2020 16:55
When will this be improved to include body fat %, water %, CO2 % & heart rate?
This biggest decision maker of why I have not purchased the scale. As I can input this info quicker than waiting for this to be uploaded to my phone or watch.
Thanks
07-22-2020 16:23
07-22-2020 16:23
I did buy one because they are still advertised as having BMI on them. They do not!!
