11-12-2019
		05:05
		06:05
			JuanJoFitbit
		11-12-2019
		05:05
		06:05
			JuanJoFitbit
Just a quick question regarding my new Aria Air scale. I was finally able to get it to sync with my phone and my Fitbit app. The weight comes through just fine but the body fat percentage does not populate in the body fat% field on the app.
The scale was touted as being able to calculate this, and to determine the percentages with the help of the app. I had to manually figure out my body fat percentage and add it to my app. What is the procedure for having this information filled in automatically by the scale? Have I missed a setup step in either the app or the scale?
Thanks!
07-23-2020 00:44
07-23-2020 00:44
The BMI is on the app, always has been. The promotion for these scales does indicate it shows on the scales which it doesn't.
08-02-2020 04:41
08-02-2020 04:41
What a waste; even the less expensive **ahem** scale calculated % Body Fat. Had I known, I NEVER would have purchased this scale.
		08-02-2020
		17:52
		05:06
			JuanJoFitbit
		08-02-2020
		17:52
		05:06
			JuanJoFitbit
How do I return my scale.
Agree I think it’s crap do you have the return information.
Moderator edit: merged reply
08-05-2020 05:51
08-05-2020 05:51
Thank you for this information! I was on the brink of returning the scale because of the missing BMI data. You would think that it shows up in the daily weight log, but I was able to find it exactly where you said.
 Best Answer09-29-2020 12:15
09-29-2020 12:15
I'm similar a build to you, 5'7" 210 lbs. I have a 34-36 inch waist. I have lots of muscles. The BMI calculation is depressing. I wish I can find a device that tells me with reasonable accuracy how much lean muscle I have versus body fat.
 Best Answer09-29-2020 14:38
09-29-2020 14:38
My cardiologist told me that BMI is a useless measurement because it doesn't consider muscle mass. She doesn't measure it at all.
 Best Answer11-11-2020 10:40
11-11-2020 10:40
Mine was calculating the body fat percentage the first few days I had it and the people in support are TELLING me I manually entered it. I CANNOT update what aria enters so no the f I did not. They are rude. I’m about to switch from Fitbit to an Apple Watch.
11-11-2020 15:08
11-11-2020 15:08
11-12-2020 10:53
11-12-2020 10:53
So which Aria scale calculates body fat?
11-17-2020 03:50
11-17-2020 03:50
There are no Aria scales that measure body fat since the Aria 2 was discontinued.
11-27-2020 18:55
11-27-2020 18:55
I’m glad i didn’t buy any Aria scales because my old one has everything in it: body fat, water, BMI, weight,... All i have to do is use a different app to keep track of everything and the weight i can put in manually in the Fitbit app on my iPhone. So I’ve basically saved myself from wasting money. Phew!!
12-13-2020 03:27
12-13-2020 03:27
I am afraid I must disagree??
In the 10 days I have been using aria air - it has calculated my body fat % - only once, on day 4, but it has shown up on the weight screen, next to my weight...
Did I do something different? or has an anomaly occurred?
		10:03
		05:08
			JuanJoFitbit
		12-30-2020
		10:03
		05:08
			JuanJoFitbit
Yes it does, but only shows up in the app.
It only shows up on the app next to your weight.
		12-31-2020
		09:49
		05:09
			JuanJoFitbit
		12-31-2020
		09:49
		05:09
			JuanJoFitbit
I totally agree. Just got the Aria as a gift. On the back of the box it says "send stats to the Fitbit app where you can check your BMI" . My weight has gone to the Fitbit App but there is no record of my BMI. I do think Fitbit has been misleading here. (I just wasted over an hour trying to get the BMI to come up. Also when you look at the scale display there is a BMI blurred out signal.) Really disappointed.
Hello where does the body fat appear. Is it in the graph that you see the body fat?
 Best Answer12-31-2020 17:13
12-31-2020 17:13
I'm having the same issue!
01-03-2021 03:58
01-03-2021 03:58
Same here! Mine were also a Christmas present, disappointed with how basic they are but I do like hiw it feeds through to the app. Seems strange as you can see where it says BMI etc in the background of the screen on the scales.
01-11-2021 11:50
01-11-2021 11:50
I just got the Aria Air because my original Aria stopped working. I was shocked to find out that it does not measure bodyfat percentage! I just assumed since it was the latest scale, it had all the previous features, plus!
01-12-2021 04:57 - last edited on 01-18-2021 18:54 by LiliyaFitbit
It's terrible isn't it! Not worth the £50 mu sister paid for it!
Best regards
01-12-2021 08:42
01-12-2021 08:42
Yes it's very disappointing!! I got mine as a birthday gift and didn't find filing for a return until the I believe three week time period I had to return it was up!!
I probably would have wanted a scale that has all the bells and whistles, not just weight. And, they're about the same price!!
01-13-2021 04:34 - edited 01-13-2021 04:35
Indeed quite ridiculous that the latest Aria scale doesn't do a simple bodyfat reading and upload it into the Fitbit app. I'm also not keen on the Bluetooth system where you need to have your phone and Fitbit app open to record the reading.
Why did they move away from the Wi-Fi option where there was uploaded directly to the Fitbit account?
I just sent my Aria Air back and will use another more capable scale and input the readings manually into my app.
