07-29-2020
08:26
11:05
JuanJoFitbit
07-29-2020
08:26
11:05
JuanJoFitbit
My Aria Air scale needs to be turned on by stepping on and stepping off quickly. If I go for the first weight it shows (by NOT stepping off quickly) it shows me as three pounds heavier than I actually am.
Apparently this is because I store it sideways in my teensy bathroom (finally found a thread that pertains to this issue.) I figured it out pretty quickly and it's not a problem. Weight 1 is always going to be three pounds higher than weights 2, 3, 4 etc.
It's not a problem, per se, I just wanted to share in case anyone else is experiencing the same thing and is confused.
Moderator edit: updated label
