Aria Air isn’t showing my Body Fat
I just bought a Fitbit Aira Air last week and it’s not showing my body fat. I read the forums and tried taking the batteries out for 20 seconds, I tried stepping on it 5 times in a row, I’ve wiped it down, I’ve moved it to different hard surfaces, NOTHING is working! It’s only recording my weight and BMI, but not my Body Fat and that’s what I’m really wanting- that’s WHY I purchased this scale!
Moderator edit: format
4 REPLIES 4
Aria Air does not measure body fat %.
Aria 2 and Aria did.
Oh my goodness- you’re kidding! How could I have missed that before purchasing!
I would really like to keep track of my body fat. Any suggestions on what product is good for that?
Thanks so much for your prompt response!
The Aria 2 did that; Fitbit no longer sells that but you might find it for sale other locations; but be sure they are authorized dealers to get warranty.  There are several other brand scales that measure body fat by same method.  I just did a quick Amazon search for "body fat scales" and found dozens.  I cannot judge the accuracy or reliability of any of them, but I think most use the same general method as the Aria scales did.  You also might consider whether they can sync automatically to the Fitbit app to record results automatically in Fitbit.
You might try these 2 other boards for more help or suggestions:
Manage Weight
Third Party Integrations  for help with which others might link up to Fitbit.
Thank you so much!
