10-31-2019
06:19
13:02
LizzyFitbit
10-31-2019
06:19
13:02
LizzyFitbit
Just bought the aria air. It has paired with my phone ok but my weight does not auto sync. I have tried logging in and out of the app etc. How do I get the aria air to auto sync my weight. This will be returned if that function does not work as what’s the point in manually adding your weight, that’s what I did with my old scales! Thank you for any help. Remember I have already logged off and on again. Thank you.
Moderator Edit: Clarified subject and updated label
01-24-2022 13:12 - edited 01-24-2022 13:13
Hi everyone and to our new members, welcome to the forums.
Thanks for your feedback and efforts while working on this matter. I'm sorry you've had this experience and if by any chance your Aria Air won't sync correctly, please give a try to the steps described in this help article.
To prevent any confusion, I'm going to close this thread from further comments. If by any chance you have a different question, I'd encourage you to create a new thread in the Help Forums to receive help from our Community. You can also check our Help Site where you'll find more information about our products, features, as well as troubleshooting tips.
See you around.
11-01-2019 06:49
11-01-2019 06:49
Hi @Guitarkid89
I am sorry to hear you are having syncing issues. Have you tried the following steps?
https://help.fitbit.com/articles/en_US/Help_article/1866/?l=en_US&c=Topics%3ASyncing&fs=Search&pn=1
11-02-2019 06:42
11-02-2019 06:42
Do you have your phone nearby with the fitbit app open when you are on the scale?
11-02-2019 06:55
11-02-2019 06:55
yes I have tried all the advice and steps it’s just simply not syncing my weight. I am a UK user and it seems to be a problem for everyone over here. Using iPhone 7 with latest IOS and most up to date version of Fitbit app
11-02-2019 07:01 - edited 11-02-2019 07:02
Im in the UK aswell mine syncs everytime. Mine has other problems nobody seems to be able to help with it, the app thinks it isn't setup and constantly tells me to set it up even though it is and sends the weight over. It also constabtly changes my unit settings from stone to just pounds on the app.
I genuinely don't think they do any testing before putting these scales on the market.
11-08-2019 11:36
11-08-2019 11:36
I’m in NZ, also on iPhone 7, and also can’t sync.
04-30-2020 14:05
04-30-2020 14:05
I am having same issue but on a Huawei p20 pro
05-02-2020 15:19
05-02-2020 15:19
I just bought my scale (May 2020) and I'm having the same issues!
05-07-2020 08:27
05-07-2020 08:27
I just got mine - same issue, only synced the initial setup
Did you get it resolved?
05-07-2020 08:36
05-07-2020 08:36
I got mine resolved. I contacted FitBit support. They had me take out the battery for 10 secs then add the device as new again. Try that. If not they may need to do something on their end first? You also have to make sure your app and watch are updated.
07-13-2020 14:35
07-13-2020 14:35
Same problem ( Canada) scale works fine, but will not sync! Grrrrr
07-14-2020 07:55
07-14-2020 07:55
Identical situation. My scale only syncs once (the first time after set up) and won't do it again. Regret this purchase.
07-14-2020 14:59 - edited 07-16-2020 05:11
Just got mine. I can get it sync after I jump through a few hoops. By that point I could have Logged it manually and been on my way. IT's advertised Instructed and even a few YouTube video reviews show all you need to do is 1 start app, 2 step on scale, 3 save results. this all after set up of course.
I found (on android both a pixel4 and S9) you have to do the following to get it to log.
1. start app
2 go tap the + on the weight tile
3.wake scale (step on it briefly)
4 wait for bluetooth connection
5 fully step on scale
6 when orange circle with check shows step off scale
7. Step back on and it logs weight.
Edit:7/16/2020 I found out that i have to force quit the app then open it.
07-14-2020
16:18
17:17
LizzyFitbit
07-14-2020
16:18
17:17
LizzyFitbit
1. How do you know when the Bluetooth is connected
2. Where do you see the orange circle
Moderator Edit: Personal info removed
07-14-2020 22:01
07-14-2020 22:01
you know if Bluetooth is connected by the "light" on the scale. The orange circle with the check mark shows up after the screen that asks you to step on the scale.
I have only got it work a couple times so far but this is the best i came up with after doing all the "fixes".
08-17-2020 15:35
08-17-2020 15:35
I recently bought an Aria Air as well and have had the same issue too. I have a Pixel 3XL phone and my Aria Air never syncs my weight with the phone. I always have to restart the phone for each weigh-in for it to finally sync or I have to completely remove and re-pair the scale with my phone's fitbit app. FitBit did a very poor job with this product. I am considering returning this product to go for a different brand instead. I do not recommend this product.
08-18-2020 10:55
08-18-2020 10:55
Yup. Same issue. I'm really tired of trying to figure this out.
08-18-2020 18:43
08-18-2020 18:43
Here's what I figured out works.
1 force quit app
2 wake scale
3 use log weight shortcut or open app get log weight
4 step on scale
5 if app changes step off scale if not start over
6 step on scale
7 tap save
This looks like it is more of an app issue not scale issue, imo.
08-19-2020 08:34
08-19-2020 08:34
Thank you. I'll try this.
08-31-2020 08:01
08-31-2020 08:01
Thanks, that worked, but I don't think all that should have to be done. What's the point of having it when I could enter it manually just as easily.
