09-19-2020
09:18
07:09
JuanJoFitbit
09-19-2020
09:18
07:09
JuanJoFitbit
I have just weighed myself on the aria air and it came up at 187.5 pounds which is registering as 13 stone 5.4 lbs which is incorrect according to all other calculators I have used, 187.5 is actually 13.38 stone, also whilst I was weighing myself throughout the previous it was coming up as 190 pounds which registered as 13 stone 7.8 pounds however this isn't correct as it is 13.57 is there a reason why this is not calculating correctly.
Moderator edit: format
09-19-2020 10:02
09-19-2020 10:02
13 stones 5.4 lb = 13.38 stones, just like it says.
Perhaps you are expecting it to break it down into stones and pounds, but it is giving it completely in stones with a decimal fraction instead.
