02-15-2021 09:19 - last edited on 02-24-2021 06:08 by JuanJoFitbit
Mine has never shown body fat % since the day I got it. Tried several fixes on here and nothing has worked. Any thoughts Fitbit?
Moderator edit: updated label
02-15-2021 09:29
02-15-2021 09:29
Unlike Aria and Aria 2, Aria Air does not measure body fat %.
02-15-2021 09:33
02-15-2021 09:33
Wow thank you! Honestly it was advertised as one of the specs and there’s a spot for it every time I weigh myself. Good to know. Thanks again!
02-15-2021 10:17
02-15-2021 10:17
I'd be interested to see an advertised spec saying that.
As to the "spot for it", if you mean there's a display spot on the scale, I suspect that's a canned display part showing several fields, only some of which get used for various models, or brands.
But you are certainly not alone. I've seen others here thinking the same thing.
One not-too-obvious giveaway, the foot plate is all one piece (I think). Ones that measure body fat need separate plates for left and right feet for sending and receiving small electric current from one foot to the other through the body.
02-15-2021 10:46
02-15-2021 10:46
Well I could have sworn when I bought it, that specific spec was listed on the box but I did opt for the air as it was cheaper so maybe that’s why. Also yes when I open the app to save the weigh in, the spot for body fat% just shows “—“. Two dashes. And you’re right as far as the foot plates. Typically I’ve seen those as well for body fat % scales. Oh well.
02-15-2021 11:15
02-15-2021 11:15
That's partly why it was cheaper; also syncs via bluetooth rather than wifi; though I've seen many having trouble with newer wifi so bluetooth might be better in some cases.
