04-19-2023
14:04
04:37
04-19-2023
14:04
04:37
When first used the scales it showed the BMI% on the capture screen but would not show it in the app.
Now it won't even show it in the capture screen.
What has caused this?
How can I get it to display?
04-20-2023 06:23
04-20-2023 06:23
Hello @JayTee13 and welcome to the Community. Can you please clarify and/or rephrase your question? You wrote confusing and contradictory statements.
Laurie | Maryland
04-21-2023 04:14
04-21-2023 04:14
Hello @LZeeW .
Many thanks for the reply.
Understand the confusion. So to clarify..
When I started to use the Aria Air, the pop up screen that shows the capture of your weight also included a line that showed % Body Fat (so my assumption was this value had come from the Aria Air).
Now that you have clarified it is something calculated in the app - the question then becomes why is it no longer showing? What has changed on the app (I cannot recall making any changes) that is preventing this value from being shown/calculated now?
any ideas?
thanks
J.T.
Best Answer04-21-2023 05:52
04-21-2023 05:52
@JayTee13 Were you using an Aria or Aria 2 before buying the Aria Air? I have an Aria 2 and an Aria Air. I got the Aria Air when it was released. I don't remember ever seeing am percent body fat in the Aria Air pop up. It's not there now, only weight. Sometimes I see a percent body fat in the Fitbit app Weight log, but it looks like a carryover from an Aria 2 weigh in. I don't have a good answer for you, other than weird stuff happens.
Please check on one thing. Your scale might be new to you, but you don't know when it was manufactured. There was a firmware update. This didn't show up as a banner on my Fitbit app, like a device firmware update. I read about it and found it in my phone's App Store. Very different from every other Fitbit firmware update.
Laurie | Maryland
