12-29-2022 10:57
12-29-2022 10:57
Got a new scale and set up using my husband's iPhone - works beautifully and as it should per the instructions.
He sent me an invite, I accepted and the Aria Air shows on my profile. I step on the scale with my phone open as directed and nothing - no weight, no save, no nothing on my phone. I've checked my dashboard and nothing there either. When I open the weight page it tells me to step on the scale to sync, but nothing happens.
I've read every topic I can find before posting - and force closed the app, reset my phone, etc. - but can't find a solution. Any suggestions?
12-30-2022 22:42 - edited 01-01-2023 09:03
I had the same problem. If you click on the "+" button in the upper right of the screen and then step on the scale it will record your weight. Not as ideal as for the iPhone users who have it automatically done but still better than manually inputting it.
Update 1/1/23: I was able to input my weight the same way yesterday but now my scale won't sync even though I have restarted everything and uninstalled and reinstalled everything. Still won't sync in the slightest. Probably going to return it after 3 days use. Smh
12-31-2022 04:47
12-31-2022 04:47
Have the same issue. Got Android (Google Pixel 6)
Yesterday morning weigh in did not start sync
- Restarted phone and it did help.
This morning, same issue
- Force quit the Fitbit App and it did help
Firmware
Also found out there is an App for updating the scale firmware from Fitbit. In my case no update was needed.
iPhone
Have one, will test if it reacts better.
01-01-2023 12:11
01-01-2023 12:11
@willow028 is this happening, even when your husband's phone is not nearby?
01-02-2023 04:56
01-02-2023 04:56
EXACTLY the same issue I came to report. First user to setup has an iPhone, it works perfectly. Second person has an Android and the sync only worked one time AND the weight had to be manually entered. 😑 Since that initial attempt at sync, nothing at all.
01-02-2023 11:40 - edited 01-02-2023 11:41
Been in Twitter chat support with Fitbit now.
They told me to reset the scale in two steps.
1. Hold the button underneath till OTA appears.
2. Then press it again for five seconds till CLR appears.
I tried to register weight with both my wife's phone and mine (Pixel 6 and 5a) with a positive result.
Will try to replicate tomorrow to see what happens.
Note. It was a little bit tricky to get the CLR message. Had to redo step 1 three times and make a perfect timing for second CLR push.
01-02-2023 11:44
01-02-2023 11:44
Yes.
Got some info from the Fitbit support team 30 min ago to reset the scale in 2 steps (see post below how to).
01-02-2023 23:24
01-02-2023 23:24
NOPE....still same issue this morning. Have to force quit app to get it to log weight...😡
01-03-2023 05:34
01-03-2023 05:34
So ~ update ~ before I posted the first time, I did reset - twice - and reset up - but I want his phone to be the main phone the scale syncs to, so did it the same way both times.
His phone has worked every day. Mine worked on Friday when he wasn't home. Didn't work Saturday-Monday. Figured maybe it was because the iPhone was nearby, so tried this morning after he left for work. Nope, that wasn't it.
Still syncs to iPhone fine but will not sync to Android. I've tried closing out everything and starting my phone fresh in the morning - nope.
Any other ideas? Appreciate the ones above as well as hearing from others that I'm not alone!
01-03-2023 05:35
01-03-2023 05:35
Yes - thought removing his phone might help, but it didn't.
01-03-2023 14:06
01-03-2023 14:06
I have an open chat with the support team. No response from them since 8:13 pm yesterday.
There is a section on the Fitbit web where you can post feature suggestions. Not sure if it's meant to be used for getting attention to a fix like WE want, but I imagine, sice people can cast a vote/upvote a post there it might be a tactic to get heard?
01-03-2023 14:40 - edited 01-03-2023 14:41
I have posted a suggestion now. Awaiting to see if it gets qualified. Will share link if it passes moderation....and then we can post the link in every similar forum thread, hoping to get people to up vote it.
I'll give it a few days and if no response from support I will try to get my mone back.
Thank you for sharing your suggestion! Our Moderation Team will review your submission soon.
01-05-2023 01:11
01-05-2023 01:11
Update. The scale has been working for me the past two days (morning weigh ins), but not for my wife. I´ve been the one who steps up first on the scale in the mornings. Now she´s the one who has to force-quit her Fitbit app.
01-05-2023 07:41
01-05-2023 07:41
Update: Worked yesterday doing nothing different, other than my husband wasn't home. Today he turned his phone off before I got on the scale - and didn't work.
The only thing I can determine is if I come in here and complain, it works the next day. 🙂
01-07-2023 02:44
01-07-2023 02:44
It looks like the "feature suggestion" did not qualify. This administrator created a new post on the forum instead with my written content. Hahaha, this is hilarious. Seems to me they don´t want to acknowledge this as something that is broken and just relying on standard answers which they copy and paste as replies. The only thing the support does is answer things like
01-07-2023 03:29
01-07-2023 03:29
Same issues here, Fitbit support seems very crappy. Hoping now that Google owns them that maybe they will improve 🤷
01-07-2023 13:13
01-07-2023 13:13
Reply from support January 7th 2023
Thanks. We verified that this is a known issue, and we're currently working to resolve this issue and hope to have a fix soon. In the meantime, we recommend keeping your Fitbit device and app up-to-date. Thanks for your patience while we work to get you back on track, and let us know if you have any other questions.
----end quote
Does anyone know for how long this has been an issue?
Hopefully the Dev team will fix this. Let's hope for the best.
01-08-2023 08:33
01-08-2023 08:33
So when I was reading the instructions for the scale it said to open the app and then step on the scale. However, 2 days in a row now if I step on the scale, get my weight, and then open the fitbit app it will log my weight automatically with my android phone.
01-09-2023 20:28
01-09-2023 20:28
Yes - return for a refund.
03-06-2023 07:38 - edited 03-06-2023 07:39
I just got an Aria Air rather than another scale that claimed it worked with the Fitbit app thinking if it's made by Fitbit, it has to work better. I had tried clicking on the + symbol and it didn't work. but, so far, it hasn't work very well. The only way I've got it to work is to force stop the Fitbit app. I'll try the + symbol tomorrow. The sad part is that I should have looked on this forum before buying it - this has been going on for more than a year!
