11-03-2021
02:17
09:50
LizzyFitbit
11-03-2021
02:17
09:50
LizzyFitbit
My new aria air scales are not weighing me correctly. They’re showing me 2 kgs light and they’re not consistent. Any ideas?
11-13-2021 10:44
11-13-2021 10:44
Are you moving the scale around? It requires several weigh-is to recalibrate. Try to leave it one place.
11-23-2021 10:16
11-23-2021 10:16
Hi @Lorrafree. Welcome on board @SunsetRunner Thanks for your great help!
@Lorrafree Thanks for bringing this to our attention. Before anything else, please note that unlike other scales the Aria Air will provide a unique measure at each weigh in. However, as @SunsetRunner mentioned, certain factors such as moving the scale, storing it up against a wall or not placing it on a hard surface may affect its accuracy. Also take in mind that your weight can vary over the course of a day depending on what you eat, drink and if you sweat or exercise.
That being said, please double check if your personal info is correct in your profile, and try taking up to three consecutive weigh-ins to recalibrate your scale.
Hope this helps.
11-25-2021 13:56
11-25-2021 13:56
Hi Patruns
really appreciate your reply. I have the scales on a hard floor and I’m not moving them. I’m comparing them against my old aria scales at the same time and they both show a different weight. I’d be delighted if I had lost 5kgs in 2 days, but I’m a bit more of a realist 😉. I’ll try the calibration technique. Thank you
11-25-2021 13:57
11-25-2021 13:57
Thanks for the tips. I’ll give them a try 😊
11-28-2021 17:53
11-28-2021 17:53
@Lorrafree It's good to see you around.
You're welcome and thanks to you for your efforts while troubleshooting your Aria Air. Please try those suggestions whenever you can and keep me posted on the outcome. I'll be happy to continue helping you with this matter.
See you around.
11-30-2021 15:48
11-30-2021 15:48
Hi there, I am having the same issue and after having tried all of the troubleshooting tips above my way continues to be very inconsistent across multiple back to back weigh Ins. Please advise how to proceed. I’ve had this scale for less than one year
12-03-2021 16:42
12-03-2021 16:42
Hi @Linrae. Welcome on board.
Thanks for joining this thread and trying the suggestions posted above. Before anything else, take in mind that the Aria Air will provides a unique measure at each weigh in and it's expected to see +/- 2 pounds of range. In case you're getting a higher or lower reading, my best advice is to get in touch with our Support team so they can provide you with further assistance. They're available via chat and phone, just click here to get connected with them.
See you around.
