02-13-2020
03:50
11:01
JuanJoFitbit
02-13-2020
03:50
11:01
JuanJoFitbit
Suddenly the scale won't pair with either droid phone. Not that hard to type in but is this just the start? Only had it since beginning of January.
02-27-2020 09:51
02-27-2020 09:51
What happens when you open the app? And weigh yourself.
Trying to pair through the phones Bluetooth should be rejected by scale.
02-27-2020 10:46
02-27-2020 10:46
Usually when I open the app and then step on the scale, nothing happens. Like this morning. But Tuesday morning, the app was open, I stepped on the scale and my weight synced. So it's entirely random now when before it wasn't. If the app was open, I stepped on the scale, it would sync.
I believe my husband's phone is now syncing every time though.
01-06-2021 06:17
01-06-2021 06:17
Why do you say that trying to connect through the phones Bluetooth the scale should be rejected? I thought that was the proper way to sync...but I still have problems with it in this manner. My phone is near by, open to the fitbit app on the today tab and the sync isn't happening.
01-06-2021 09:09
01-06-2021 09:09
Because the Aira Air has a Low Energy Bluetooth and all setup must be done through the Fitbit app.
Once the Aira Air has been setup to your Fitbit Account, the Fitbit App will pair the Aira Air to the phones Bluetooth. This is no different than any other Fitbit.
So what you are saying is the Fitbit app is open, you way your self, the Aira Air then gives you an error of some type?
01-06-2021 09:53
01-06-2021 09:53
03-07-2022 05:16
03-07-2022 05:16
This is happening to me too. Stumbled upon this hoping for an answer but this has been open for a while with no response. Did it ever get fixed?
03-07-2022 07:20
03-07-2022 07:20
Yes @Rachelmomof6 this is a Bluetooth Low Energy device and you will not be able to pair through the Bluetooth settings.
You must first setup the Aria Air using the Fitbit App. Once setup the Fitbit App will ask for permission to pair through the phone.
