05-19-2020 06:12
05-19-2020 06:12
Hi there,
I am losing my mind here. I keep trying to connect my Aria to the wifi (which used to work) and I cannot get it to find my Wifi network - despite trying everything (and yes, the wifi network does work). Here are my responses to a prior post from fitbit. Can anyone help??
I remove the batteries, put them back in, get the set up screen on the scale, get my phone to identify the scale / sync with the scale, the scale then detects several wifis - but it fails to detect MY wifi even though (1) the wifi is working (2) it’s right next to the router and (3) the name of the router is only letters. I have gotten stopped at this part of the set up about 10 times.
2. What is the make and model of your router?
Xfinity gateway - I just got a new one (2020).
3. What is the distance between the scale and the router during set up?
6 inches
4. Does your WiFi password exceed 31 characters or spaces? Does it include any non-alphanumeric characters (such as ! or &)?
NO and NO
5. What is your scale's firmware version? You can find this number by removing the battery from the scale for 10 seconds, placing the battery back in the scale, and turning the scale back over. On the display, you will see the letter "V" followed by a number (e.g. V29). This number represents your firmware version.
v39
Any help would be great - I'm losing my mind here!
05-19-2020 14:45
05-19-2020 14:45
Having the same issues! Not synced for 7 days. Joining this incase you get a reply ☺️
Best Answer05-23-2020 21:12
05-23-2020 21:12
yes having the same iss ue started on 17th april 2020 worked the day before tried resetting but wont locate network
Best Answer05-27-2020 14:23 - edited 05-27-2020 14:26
The Aria only uses 2.4GHz wifi, it doesn't use 5GHz.
The protocol it uses is an older one, 802.11b. Check your router is set up for that mode. Some routers have a legacy setting for b mode. (On mine it's "Legacy b/g"). <- this is a common issue where the Aria was connecting and suddenly starts reporting 'No WiFi'.
The Broadcast SSID setting must also be set to "On" in the router. If you Aria can't find the WiFi during setup, I'd check that first.
Good luck.
Best Answer05-27-2020 14:33
05-27-2020 14:33
