02-20-2017
08:48
14:53
02-20-2017
08:48
14:53
I've had the Aria scale for over a year now (got it for Christmas in 2015), and it had been working and syncing with the app fine. Then for some reason, on November 9, 2016, it stopped syncing. I didn't notice it hadn't been syncing until after Christmas, which means that I'm past the 1 year warranty that they give for their devices. Are there any fixes to this? I've gone through the setup process at least 20 times now, to no avail.
I've also checked my router settings (to the best of my knowledge, everything looks good), and I still can't get it to update or sync. On my account, it says that the last sync was still in November.
12-09-2017 08:33
12-09-2017 08:33
I am having this same problem with my aria not syncing and have tried everything that Fitbit suggests and nothing works. I have not found anyone that has found a resolution that works
12-09-2017 08:40
12-09-2017 08:40
At least yours is still under warranty. I guess I’m out of luck
01-01-2018 15:05
01-01-2018 15:05
Bought Aria scale last week. It synched once. Now it does not sync properly. Went through reset procedure. The current new weight has replaced last weeks weight with the old date showing. The old weight is no longer there. The new date is not there. Wish I would have read all the error posts before I bought this **ahem**.
08-05-2019 14:20
08-05-2019 14:20
Sigh....
08-23-2019 05:50
08-23-2019 05:50
I have tried everything, including setting up again. My scale still will not sync.
08-23-2019 05:52
08-23-2019 05:52
My scale is several years old, and as of this mornings NV won't sync. I have reconn cited, re set up, . . . Help please.
08-23-2019 05:53
08-23-2019 05:53
I eventually gave up and bought a scale from weight guru that syncs to the Fitbit app
09-14-2019 07:40
09-14-2019 07:40
I am blocked from viewing the referenced post
01-22-2020 14:35
01-22-2020 14:35
My aria won’t sync as well. I have tried starting from scratch but it won’t even let me do that
please help moderator
01-22-2020 14:49
01-22-2020 14:49
05-03-2020 18:28
05-03-2020 18:28
I did, got a scale from a different company
05-26-2020 03:17
05-26-2020 03:17
I have several WiFi Printers, one in particular if it is on, my Aria Scale will not sync to the Network. Once I turn that WiFi Printer off, my Aria Scales resume working properly. Just a thought, check all your WiFi devices and make sure they are not conflicting with the Aria Scales. I hope that the solution is as simple as it was for myself. Good Luck.
