01-09-2020
00:28
05:13
JuanJoFitbit
01-09-2020
00:28
05:13
JuanJoFitbit
I bought an aria scale years ago, and it fell out of use several years ago. Recently, I decided I needed to focus more on my health and weight, so I replaced the batteries in the scale. It took some doing to get it to turn back on. I re-synced it to my network, just to be certain, but now it doesn't display my weight properly.
It claims that I weigh 30 lbs, which I know to be quite false. I know from a cursory search that there doesn't seem to be a way to manually calibrate the scale itself, but I was wondering if anyone else had any suggestions.
I'd would rather avoid buying a new scale if at all possible, and previously when the scale worked, it worked very well.
Thank you for any help!
SKA
Moderator edit: format
