05-09-2020
11:30
05:20
JuanJoFitbit
05-09-2020
11:30
05:20
JuanJoFitbit
I’ve been using my Aria scale consistently and hovering around the same weight for a while and then I switched out the batteries because they were low and stepped on the next day to an increase in 20lbs. I just want accurate numbers regardless of what they are and this is clearly not calibrating correctly for whatever reason. obviously it’s not possible to gain 20 lbs overnight. What the heck Fitbit. And now it signs me in as a guest?
Moderator edit: format
