03-08-2022 07:38 - edited 03-08-2022 09:06
I currently have an Aria, which is fine. I'm thinking about upgrading to an Aria Air.
Has anyone done this? Is it worth it?
03-08-2022 07:42
03-08-2022 07:42
Hi @HackneyCat having no experience with the scales, I do want to share the one thing I do know - the Aria Air doesn't show the body fat percentage. It's the one issue I've seen posted on these forums.
03-08-2022 09:12
03-08-2022 09:12
Thankyou! My Aria is pretty flaky with bodyfat, too, but I just ignore that 😂 Otherwise it's been fine, synchs well, works with more than one user etc.
03-08-2022 09:25
03-08-2022 09:25
@HackneyCat then it seems like you're happy and fine to stay with the Aria. I probably wouldn't check body fat if I had a scale too.
03-08-2022 10:06
03-08-2022 10:06
@Odyssey13 thing is I've had the Aria 8 years and it's going to fail sooner or later. Plus I'm about to get a 40% off fitbit devices voucher (due to Ionic product recall) so thought this would be a wise time to upgrade.
I'm hoping the newer scale tech will be an improvement on the 8 year old tech 🤔
03-22-2022 13:58
03-22-2022 13:58
Hey mate, did the same thing.
Scales arent included in the discount, only trackers are in the discount store. was suprised but they really only recalled the trackers so the deal of 5 devices is more than fair IMO. the new scales dont show body fat percentage on the screen and so far you have to open the app, go to weight , and log the bluetooth measurement. I have really become used to the old method of everything being recorded and updated automatically with a body fat display to encorage the days excersise. morning routine of just stepping on scales and then evry few days looking at weight trands on the graphs in the app has been awesome. I dont think that happens here.
I am hoping when the tracker shows up (sense) that the scales auto sync with the tracker. will find out.
11-15-2022 06:10
11-15-2022 06:10
I wish I had not bought the Aria Air. Thankfully I have the box because its going back. It does not autosync weight. You have to get your phone and tell it to save the weight. My old scale could tell the difference between two users and automatically put weight on fitbit. NOT THIS ONE
