02-09-2024 14:35
02-09-2024 14:35
If you look at the aria air display you can see beside kg is the chinese unit "公斤". I happen to be chinese so I wonder if I can change the scale to use this unit. But the change unit button on the back only cycle between st, lb, kg. So how to change unit to chinese?
02-10-2024 10:53
02-10-2024 10:53
Hello @GummybearCanada and welcome to the Community. I've always known that there are many icons that won't light up on an Aria Air, but I don't think you can get your scale to measure in Chinese units. The Fitbit app only lists st, lb, and kg as weight units. The screen has a battery charge icon that doesn't light up. The Aria Air was released in 2019, is a very simple scale, and doesn't have the hardware to estimate body fat percentage. But it has some of those icons, too. None of us know why the unusable icons are there.
Laurie | Maryland
