09-06-2015
08:10
14:53
09-06-2015
08:10
14:53
12-19-2018 03:51
12-19-2018 03:51
@Unhappy_Cust I'm sorry to hear about the the experience you had with your Aria scale. I really appreciate your feedback and comments since this helps us to keep improving.
@Hatter222 Your feedback is greatly appreciated. Thank you for sharing this info.
01-03-2019 07:22
01-03-2019 07:22
I have a different problem BUT based on my understanding of electronics and experience stepping on and off my scale, it seems like a weight detection sensor is intermittently sending a signal that you have stepped off after a short period.( STEP ON is displayed always) . Although sure to void any warranty, disassembly may reveal the culprit. Dust, debris , moisture, bad connection, or faulty sensor.
01-05-2019 08:16
01-05-2019 08:16
@Bouchonne Thank you for joining us in this thread! I'm sorry to hear about the issue that your Aria scale is experiencing. I'd like you to try taking out the batteries and clean the contacts of your scale with a cotton swab and a little bit of alcohol. This will remove any dust that the contacts accumulate. Once you've done this, put the batteries back in and see if the issue gets fixed.
Keep me posted!
01-05-2019 08:46
01-05-2019 08:46
01-05-2019 15:08
01-05-2019 15:08
01-10-2019 05:42
01-10-2019 05:42
@Hatter222 Thank you so much for the information!
@Bouchonne Thank you for getting back and trying the workaround mentioned above. Regarding your inquiry, I'd like to forward your case to our Support team so they can investigate this issue and provide a solution. You will receive an email from them soon.
Let me know if you have any doubts!
02-17-2019 05:37
02-17-2019 05:37
I have the exact same problem. Definitely a Fitbit issue. Not a batteries issue.
02-19-2019 03:42
02-19-2019 03:42
@tmatos Welcome aboard to our Fitbit Community! I'm sorry to hear that the batteries that you've put in your Aria have drained fast. I'd like you to try the following workaround and let me know if the issue persists so I can assist you accordingly: Please take out the batteries, clean the contacts of the scale with a cotton swab and a little bit of alcohol in order to remove the dust that the scale accumulates.
After this, put the batteries back in (make sure they're not rechargeable and they're are alkalines preferably).
Keep me posted!
02-19-2019 04:20
02-19-2019 04:20
You have been giving the same answer for over a year and it doesn’t work. Getting old.
02-21-2019 03:54
02-21-2019 03:54
@thompsoe85 I know that this is frustrating for you. Thank you for your comments.
02-21-2019 05:01
02-21-2019 05:01
I am also having issues with my Aria scales so i contacted customer services and they useless. Just told me it broken. Well yeah, thats why I contacted them and they couldn't do anything because it was out of warranty
This is 2019 and customer services is extremely important in this digital age.
I will never but anything fitbit again terrible service for what is clearly a know issue after reading the posts on the forum
02-21-2019
09:47
10:37
JuanJoFitbit
02-21-2019
09:47
10:37
JuanJoFitbit
The first 3 or 4 times I read this, I thought you were referring to the contacts for the batteries. After considering the issues leading to your comment, I believe you are referring to the pads that are stood on. The foot contacts on the top surface of the scale and the space between them.
And to add to the confusion, replies to posts are placed at the end of the thread making it difficult if not impossible to follow the discussion. Communication is the key to our success.
What did Hatter 222 say? ...and when?
Moderator edit: merged replies
02-21-2019 10:11
02-21-2019 10:11
02-21-2019 10:23
02-21-2019 10:23
02-22-2019 08:37
02-22-2019 08:37
I did remove the app from my device and reinstalled it twice and it makes no difference batteries still drain.
02-22-2019 08:51
02-22-2019 08:51
02-22-2019 12:02
02-22-2019 12:02
I cant figure out how to delete it from my account. How do you delete the scale?
02-22-2019 21:29
02-22-2019 21:29
02-22-2019 22:02
02-22-2019 22:02
02-27-2019 10:58
02-27-2019 10:58
@Beardo10 I'm sorry to hear that your Aria scale is no longer under warranty. I understand how you feel about this.
@Bouchonne I'm sorry for the late response. I was able to get in touch with our Support team and was told that they will get in touch with you via email. Please keep an eye on your email account.
@Hatter222 Thank you so much for sharing the workaround that you followed. I'm glad to hear that your Aria scale is working properly. Don't hesitate to get back if you need further assistance.
@tmatos I'm sorry for the late response! I want to follow up on your case and would like to know if the issue persists or if your Aria is working properly now.
@DocDRD Regarding your inquiry, please take a look at this post, which explains how to remove your Aria scale from your account.
I'll be around if you guys need further assistance!
