09-06-2015
08:10
14:53
09-06-2015
08:10
14:53
03-06-2019 10:39
03-06-2019 10:39
Best Answer03-06-2019 12:36 - last edited on 01-31-2020 18:09 by LiliyaFitbit
I wish I knew. Maybe we all need to post on various social media shaming the company
03-06-2019 16:46
03-06-2019 16:46
03-27-2019
10:37
11:03
JuanJoFitbit
03-27-2019
10:37
11:03
JuanJoFitbit
That's disappointing, but I appreciate you letting me know. I just added the Charge 3 to my arsenal of Fitbit products, but should probably just jump ship and switch to apple too. Will have to order a new scale today.
Agreed, time to storm the Twitterverse!
Moderator edit: merged reply
04-05-2019 00:05
04-05-2019 00:05
Only solution I had was to take one battery and flip it in place till I used it again. Annoying but worked. Now I get ERR and even that does not work.
Best Answer04-08-2019 12:30
04-08-2019 12:30
I just started having the same problem. Light always on, battery drain in 2 weeks. Plus always says no WiFi. From all the complaints from so many people it's headed for the trash.
04-08-2019 22:31
04-08-2019 22:31
Best Answer04-09-2019 14:34
04-09-2019 14:34
I’m having the same issue! I replace the batteries ALLLL THE TIME!
Best Answer04-10-2019 07:27
04-10-2019 07:27
Best Answer04-10-2019 07:58
04-10-2019 07:58
Best Answer04-10-2019 09:50
04-10-2019 09:50
Best Answer04-10-2019 12:27
04-10-2019 12:27
Best Answer05-05-2019 15:08
05-05-2019 15:08
06:35
11:04
JuanJoFitbit
05-19-2019
06:35
11:04
JuanJoFitbit
I solved the problem. Working perfectly now. Will try to explain as simply as I can Took the back cover off. The are 4 strain gauges (resistive sensors) embedded in the feet assembly. Upon inspection, one of them appeared ajar. Popped the assembly out of the main case noticing that two of the 3 plastic flex points that harness the sensor were broke. Used JB weld and a tooth pick to apply and a hobby clamp to hold the entire foot aligning the points to cure overnight. Reassembled and works like new. Have pictures but hard to post here. Poor design that probably broke points sliding scale across tile.
Just to add why this affects the battery. The four strain gauges create the legs of a wheatstone bride that is the input to the analog front end to the digital processor. When one of these sensors is not calibrated to the other 3 (due to the broken harness) it causes the processor to go into a loop of searching draining the battery.
That was wheatestone "bridge". Wiki it and it will make sense. I'm usually a lurker but thought I would chime in because earlier post on this helped me get to this point. Thanks for your help as I was about to throw mine out too.
05-19-2019
07:50
11:06
JuanJoFitbit
05-19-2019
07:50
11:06
JuanJoFitbit
Thank you 🙏🏻 so much for taking the time to explain this! Going to check mine!
Thanks so much for taking the time to explain this!! Going to check mine..
Sent from my iPhone
Best Answer05-19-2019 19:25
05-19-2019 19:25
Best Answer06-19-2019 20:02
06-19-2019 20:02
Yeah, I'm done supporting FitBit. Their product design for real world use is abysmal. My Aria is out of warranty and has been going through the "step on scale" cycle that every other person has complained about and eats batteries. My wife and I have the Charge 2. The band on my wife's broke twice and mine broke once; all at the same faulty spot of the band. She went and upgraded to the Charge 3, but I refuse to. When this band breaks I'm off to something else that's not FitBit branded.
Now that everything is IoT enabled I'm sure to find a different scale to replace this garbage. Nokia actually has a decent product at a lower price point.
10-06-2019 05:13
10-06-2019 05:13
Yes, the same thing is happening to me. I like this scale- however it doesn't cycle off and it doesn't sync. I absolutely will not replace the batteries twice a month.
Can anyone from Fitbit help us please? Is this a defect? Is there a secret move we are not doing?
thx!
11-10-2019 06:52
11-10-2019 06:52
Same issue but it’s now draining new batteries in less than a DAY! I am taking the batteries out after each use now which is a pain until I can buy a different scale. This scale is an expensive piece of junk. My parents have had their basic digital scale for 15+ years with no issues in comparison.
