Aria body fat error solved!
ANSWERED
I was at 27 % and the next day 42% so after searching the forum and seeing it was a common issue I took the batteries out and put them back in to no change. So then I remembered the other day my time zone randomly changed so I went in because of other suggestions and check to see if I had change from male to female and it had not so after trying several other things I went in and changed it from male to female saved it waited for a little bit changed it back from female to male and now the body fat is back to 27%.
Moderator edit: format
1 BEST ANSWER
Accepted Solutions
1 REPLY 1
