03-13-2018
14:14
11:05
JuanJoFitbit
03-13-2018
14:14
11:05
JuanJoFitbit
After using My Aria for 2 months, it suddenly stopped registering the correct body fat. At first my bf was 18.7% and one day when I weighed myself, it shows that I was 9.2% only. My bf lowered 11.5% over night and I knew it wasn’t right. (I weigh myself same time every morning). Also, I know how to measure bf manually using a caliper and 18.7% was right on the money. So what is the fixed for this issue. Obviously, I’m not the only one having this problem. Your quick response is greatly appreciated. Thanks.
02-13-2019 06:14
02-13-2019 06:14
Hi,
I have lost 13 lbs, but the fat percentage has not changed. I took out the batteries for 15 seconds and weighed myself 5 times, and it still has not adjusted. Please help!
Best,
Whitney
Best Answer02-13-2019 10:04
02-13-2019 10:04
No, they haven’t, mine continues to say bf everyday and they wouldn’t do anything about it because it was just out of warranty. So now I and so many others just have a really expensive useless scale....good luck!
Best Answer02-14-2019 03:59
02-14-2019 03:59
@Wdd440 Thank you for joining us in this thread and our Fitbit Community! I'm sorry to hear that your Aria is not providing accurate body fat readings. Thank you for troubleshooting this issue before contacting our forums. Please check out your profile settings (weight, height and gender) are updated. Make sure to change the settings if necessary through your web-based Dashboard and let me know if the settings are correct.
@SunsetRunner Your feedback and comments are greatly appreciated.
Best Answer02-15-2019 00:08
02-15-2019 00:08
The suggestion resolution did not work. Change battery and weight self 5 times - each percentage different with last one 15.3% which is at least 3.6% inaccurate. What is the margin of error on the aria scale?
Best Answer02-16-2019 06:11
02-16-2019 06:11
Best Answer02-16-2019 08:26
02-16-2019 08:26
Tried the troubleshoot guide 2x and getting a new set of bf %. Now around 35, so somewhere between the (correct) 25s and the previous 43s.
Any ideas?
Best Answer02-21-2019 04:58
02-21-2019 04:58
@PhilipB325Dub @Wdd440 @HeinS Since the issue persists after following the recommended troubleshooting steps. Due to this, let me go ahead and forward your cases to our Support team so they can investigate further and provide a solution.
You guys will receive an email from them soon.
Let me know if you have any doubts! ![]()
Best Answer06-02-2019 13:29
06-02-2019 13:29
I am having the same issues with the body fat not being accurate. I tried removing the batteries and putting then back in and it didn't help. What was the solution/outcome as I'd really love to have my scale working correctly again.
Best Answer06-02-2019 14:00
06-02-2019 14:00
06-02-2019 23:44
06-02-2019 23:44
Best Answer06-03-2019 02:38
06-03-2019 02:38
The gender is correct. I've had this scale for years and have never had a problem. Now all of a sudden it is telling me my BTP is 5%. I know this is not correct. I've tried changing the batteries, that doesn't work either.
Best Answer06-03-2019 09:49
06-03-2019 09:49
Best Answer06-19-2019 23:09
06-19-2019 23:09
Finally!!!
Many thanks @Alfanino !
It is not possible to do in the Android app but on the web Dashboard and IOS it works.
at the Android app doesn't do this but on the web and IOS it works.
It is very strange that Fitbit support does not refer to this.
Best Answer07-02-2019 06:01
07-02-2019 06:01
Hello for some reason my Aria is measuring wrong my fat%, is there any effective way to fix it?
Thanks, Eduardo
Best Answer10-07-2019 23:28
10-07-2019 23:28
I’ve recently change my WiFi hub and reset Aria as published. My body fat has jumped from 22 to 41. I’ve tried all the suggestions on the forum but the fat is still incorrect??!!!
Best Answer10-08-2019 07:51
10-08-2019 07:51
Best Answer10-08-2019 08:25
10-08-2019 08:25
00:38
11:04
JuanJoFitbit
12-24-2019
00:38
11:04
JuanJoFitbit
Just dropping in to say I've tried the steps as instructed many times within this thread but my Aria 2 scales are still showing very low 6.8% bf.
Using the boditrax machine at the gym shows I am 13.7%.
I am aware that the scales at the gym have a much better reading, but my scales are way off. What else can I do to correct them?
After doing some reading through other guides I managed to find where the 'lean mode' toggle was and turned that off. Body Fat is now showing a more reasonable percentage.
Within the app click your Profile Icon > Click Aria 2 > Click Users > Click your Profile Icon > Toggle Lean off
This shows a more realistic %
Moderator edit: merged reply
Best Answer03-11-2020 22:25
03-11-2020 22:25
I’ve had a Fitbit wearable watch for 6 years now. I have ARIA scale that we’ve had since firT one cake out.
Recently I have been exercising and losing weight, my body fat percentage was it 26.4% few days ago, now it’s giving me somewhere between 36% and 39% body fat. I’ve done my own troubleshooting by taking the batteries out, I’ve been online two different times to chat, and still having the same problem. Please help!!!
Best Answer03-12-2020 05:17
03-12-2020 05:17
