06-10-2015
18:32
04:13
JuanJoFitbit
06-10-2015
18:32
04:13
JuanJoFitbit
I recently had to change out my wifi router. It is the exact same type as my previous router that was connected to the scale but for some reason this scale will not connect to the new router. Oh it was a nightmare connecting the scale to the first wifi as well, but I am over it. !!!!! I have been trying for three days. Shame on you fitbit for putting out such subpar material. some one needs to tell me how to fit this setup or I want my money back. My scale is saying that it has detected the networks but my network does not appear to connect to it. I should have bought a Withings scale. uggh.
Moderator Edit: Title change for clarity
03-13-2018 05:17
03-13-2018 05:17
You could try that - turn everything else off, then reboot the router and see if it works. The problem is that when the other devices reconnect, the router will probably switch back to the "n" mode. bgn routers will work on one or another of the modes but not all three at once.
03-13-2018 05:20
03-13-2018 05:20
*sighs* I will look into finding another router. Thank you so much for all of your help!
03-13-2018 11:22
03-13-2018 11:22
03-13-2018 16:27
03-13-2018 16:27
After readouts that increased up to 5% for body weight and 3 kgs for weight over night I have given up on using this expensive paper weight as a means of accessing valid data.
Dumped it and bought weight watchers latest . Synced immediately, gives % bone density and water content and about1/3 the price !
03-14-2018 05:51
03-14-2018 05:51
03-21-2018 14:55 - edited 03-24-2018 10:04
I had the same problem
03-22-2018 13:46
03-22-2018 13:46
03-24-2018 08:57
03-24-2018 08:57
Hi everyone! I'm sorry to hear that your Aria scale have experienced setup issues. I'll be happy to assist you and find a solution so you can connect your scales. Please make sure that your router runs the protocol 802.11b, the bandwidth is 2.4GHz and your WiFi password is alphanumerical only. In the meantime, please let me know if you are getting any error message during the setup.
@EdmundC Thanks a lot for your constant help and contribution my friend!
See you all later guys!
03-24-2018 09:46
03-24-2018 09:46
03-24-2018 17:56
03-24-2018 17:56
03-26-2018 09:02
03-26-2018 09:02
I have found an awesome solution to the issue. The Weight Gurus Bluetooth Scale $54.99 on Amazon. It requires no WIFI at all just Bluetooth on your mobile device. Turn on your Bluetooth, open the app, weigh, and immediately there is all of your information. If you have connected the app to your Fitbit App, Google Fit, My Fitness Pal or Under Armour apps it sends the information directly to those apps as well. I weigh, and look at my Fitbit app and the information is on there. I can't believe I wasted so much time trying to get this brick of a scale to work! (Fitbit aria). Shame on Fitbit for having a scale that does not work for the majority of it customers.
03-26-2018 22:03
03-26-2018 22:03
Tom I am buying a different scale due to the undue stress the Aria has caused me and because of the poor technical design. Your assessment is spot on!
04-08-2018 19:59
04-08-2018 19:59
So, are you confirming what EdmundC is saying? That the router needs to run the 802.11b mode only and that 802.11b/g/n mode will not work? My Comcast Arris router only has an option to switch between b/g/n or g/n.
Thanks
George
04-09-2018 04:35
04-09-2018 04:35
Not in the least. I got it to work, don't ask me how. The computer lingo discussed here is well above my knowledge level. I have an ASUS router of my own and it works, that's all I know.
Oh......and Fitbit is garbage, I know that too............
04-09-2018 07:37
04-09-2018 07:37
The only thing I know for sure is, it is a fitbit issue and they need to improve their technology, sometiems resetting the router fixes it, sometimes it doesn't.
I love the concept of fitbit but have had to return every single item I ever bought that is a charge2, headphones and aria. I love them when they work but I suspect next time around I'll look for a more robust supplier.
04-10-2018 04:27
04-10-2018 04:27
@Tom61 I'm glad to hear that you resolved the the syncing issue that your Aria was experiencing! I appreciate the update and your feedback.
@Pat_C @lstocker @GEOC59 @Capio78 I really appreciate your feedback and comments about the setup and syncing issues that your Aria scales are experiencing. I want to follow up on this and would like to help to turn that bad experience into a good experience. Please let me know what is the make and model of your routers.
If you guys have Comcast routers, please try the workaround that shared @prncssgeek in her post and let me know how it goes.
Keep me posted!
04-20-2018
13:15
07:59
JuanJoFitbit
04-20-2018
13:15
07:59
JuanJoFitbit
Whats the best way for me to return this product? FitBit sucks. Its like right up there with windows vista. Its a failed product. Just give me my flipping $150 hard earned dollars back immediately.
Moderator edit: format
04-23-2018 04:30 - edited 04-23-2018 04:30
@PNW5321 Welcome aboard in our Fitbit Community! I really appreciate your feedback and I'm sorry to hear that you decided to return the scale. I'll forward your case to our Support team so they can help you with the return process. You should receive an email from them soon.
For more information about the return and warranty policies, please visit this page.
Let me know if you have any questions!
05-02-2018 12:55
05-02-2018 12:55
I've tried over a dozen times, it will be out the window in a minute... It's always been a pain to set up when batteries die or the wifi has been changed, but this time it's beyond a joke, the router Virgin hub 3 and I working s fine, it is 802.11b and I'm on the 2g it just will not connect at the last stage.. This is the biggest waste of time and money ever. Fitbit need to pull their finger out and sort this out!
05-07-2018 04:12
05-07-2018 04:12
@Mazfrd Welcome aboard in our Fitbit Community! I'm sorry to hear that your Aria scale is not connecting with your network as it should. I want to follow up and would like to know if the issue persists or if it could be set up properly.
Looking forward to your response my friend!
