06-10-2015 18:32 - last edited on 02-18-2021 04:13 by JuanJoFitbit
I recently had to change out my wifi router. It is the exact same type as my previous router that was connected to the scale but for some reason this scale will not connect to the new router. Oh it was a nightmare connecting the scale to the first wifi as well, but I am over it. !!!!! I have been trying for three days. Shame on you fitbit for putting out such subpar material. some one needs to tell me how to fit this setup or I want my money back. My scale is saying that it has detected the networks but my network does not appear to connect to it. I should have bought a Withings scale. uggh.
Moderator Edit: Title change for clarity
09-24-2019 16:03 - last edited on 02-18-2021 04:18 by JuanJoFitbit
This problem seems to be very common. I am surprised Fitbit Does not addressit or provide the fix more easily.
1. the scale does not see 5gh networks
2. one must be savvy enough to know how to set your router to 802.11b. what ever the f that is.
going back to using a Garmin and dumb scale.
what is b/g/n?
Moderator edit: merged reply
09-24-2019 17:24
09-24-2019 17:24
09-24-2019 18:35
09-24-2019 18:35
09-25-2019 05:17
09-25-2019 05:17
09-25-2019 09:57 - edited 09-25-2019 10:02
Ok, i'll try and make this an easy fix for everyone ... BUT ... ALL MODEM MANUFACTURES DO THINGS DIFFERENTLY. So, you probably will have to figure stuff out on your own too.
First off, to try and put this in non-tech speak, your wireless things (modems, Access Points [AP]) have different languages that they speak in. If your device doesn't speak that language it can't communicate (and connect to) the wireless modem/AP. Most modems/AP have options for you to allow the old methods still work but they sometimes change things so it's not a default.
Back story: All technology moves forward and old communication methods get dropped as "normal communication types" change ... after a certain amount of time. Just like you couldn't connect a 20 year old cell phone to the new networks cell phones use now. This should just be a simple change in your settings IF THIS IS YOUR PROBLEM.
To connect to your wireless modem, look on the device itself. There most likely is a sticker that will say something like "https://192.168.1.1" and then a user name and password. Go to your web browser (which you probably are already in reading this) and put that in. If that doesn't bring up a login page for you, try "https://192.168.1.254" . If you get some message about communication type try dropping the "s" in https ... so http://192.168.1.1. Login with the user / password from your devices sticker.
Next find a tab/menu for Wifi and go there. Look for something that says "band" or 2.4Ghz and there should be a drop down or options there you can change. Change it to something that is probably "b/g/n" .. something with all 3 is probably your option. See this for an example https://i.stack.imgur.com/KBFbn.png You're might not look the same but this should get you moving forward. Save your settings and try to connect your scale again.
Hope this helps someone.
ps. FITBIT ... for FFS add this to your help pages.
09-25-2019 10:47
09-25-2019 10:47
Thx for the great reply,
I moved from a personal router to Cox Panaoramic Wifi yesterday; modem/router combined. It does not operate as separate bands. Do you have any experience with these?
09-25-2019 12:07 - edited 09-25-2019 12:08
From this page https://www.cox.com/residential/internet/panoramic-whole-house-wifi.html it looks like 'b' is not covered.
"The Panoramic Wifi Gateway is the only Wifi Modem Cox offers for rental. This device combines a DOCSIS 3.1 (3.0 for Internet Starter, Internet Essential and Internet Preferred) cable modem with a powerful 2-port gigabit wired router, dual band 802.11 AC wireless router which also supports 802.11 A/G/N."
Looks like you are SOL.
09-25-2019 12:38
09-25-2019 12:38
Idic!
I appreciate the effort. I found the same.
Funny, I have a perfectly good router that I am sure I could set as needed to 'b'. I also read the 'b' devices slow performance throughout the network. It's time for Fitbit to build products that keep up with routers. Anyway, I am going to go back to my old dumb scale and log weights.
Cheers
09-25-2019 15:46
09-25-2019 15:46
Not defending any manufacture that uses 'b' but for the amount of data that a scale needs to send, 'b' is probably perfect and maybe even keeps cost down.
09-25-2019 22:15
09-25-2019 22:15
Hi, Idic. Great advice you give. I agree that 802.11b has sufficient bandwidth for the amount of data. My issue with Fitbit using 802.11b is twofold Firstly, the range is terribly short, at least with my a/b/g/n/ac dual band modem. The scale will only reliably sync when in the same room as the modem. The second is that the technology is just old. It would be like a mobile phone manufacturer selling a 2G phone. This thread goes back 4 years!
09-26-2019 07:44
09-26-2019 07:44
Huh, interesting John. In my house the scale is on the top floor and my wifi router is 2 levels down in the basement and on the other side of the wall with all the ducting. I havent seen it have any problems connecting and sending data. I wonder why there is the differences.
But .. no disagreeing about the age of the 'b'. If they update the scale it defiantly should leave that tech in the past.
IM SURE THEY ARE READING THIS THREAD FOR THE FEEDBACK FROM THEIR USERS. 🙂
09-29-2019 23:14
09-29-2019 23:14
12-04-2019 02:15
12-04-2019 02:15
I couldn't get my Aria 2 to attach to my new router. So my old router was still working and I made it a slave to my new router and attach my Aria to the old rout WiFi2.4g. Also I've found taking out one battery doesn't help you need to remove all three for about 10 seconds.
Now I have four WiFi networks and everything works great.
Jerry
12-04-2019 05:15
12-04-2019 05:15
12-04-2019 08:08
12-04-2019 08:08
To use the Aria 2 scale your router needs to be able to support the old protocol 802.11b.
Jerry
12-04-2019 14:55
12-04-2019 14:55
12-05-2019 05:24
12-05-2019 05:24
Aria 2 works great if you are using an older router. The router needs to support 802.11b some newer routers don't. Check to see if your router supports the older wifi protocol. Works for me.
12-07-2019 02:55 - edited 12-07-2019 02:56
This thing isn't worth the hassle.
01-05-2020 10:59
01-05-2020 10:59
my aria scale keep saying error when i try to connect it to the new router
01-05-2020 15:10
01-05-2020 15:10
