06-10-2015
18:32
04:13
JuanJoFitbit
06-10-2015
18:32
04:13
JuanJoFitbit
I recently had to change out my wifi router. It is the exact same type as my previous router that was connected to the scale but for some reason this scale will not connect to the new router. Oh it was a nightmare connecting the scale to the first wifi as well, but I am over it. !!!!! I have been trying for three days. Shame on you fitbit for putting out such subpar material. some one needs to tell me how to fit this setup or I want my money back. My scale is saying that it has detected the networks but my network does not appear to connect to it. I should have bought a Withings scale. uggh.
Moderator Edit: Title change for clarity
07-27-2017 08:24
07-27-2017 08:24
Best Answer08-04-2017 12:30
08-04-2017 12:30
from mobile device. Scale recognizes wifi but won't sync.
Best Answer08-04-2017 13:03
08-04-2017 13:03
Hi @ntlake, from a mobile device, first review http://help.fitbit.com/articles/en_US/Help_article/1171
to verify your home network wifi password before starting the procedure so you know your iPhone is on the base wifi (and that the password doesn't have any "special characters" important it be only numbers and letters)
Now navigate with the safari browser on your phone to http://www.fitbit.com/scale/setup/start
and hit the pink button to get walked seamlessly through - be sure when the dialog asks if you are on the home network wifi you are, sometimes takes a moment to switch back from the Aria created one (you can be absolutely, positively for sure by tapping the grey "settings" icon and seeing what wifi ntwk name is listed next to "Wi-Fi"
Let us know how it goes...
WmChapman | TX
Ionic, Versa, Blaze, Surge, Charge 2, 3 SE, AltaHR, Flex2, Ace, Aria, iPhoneXR "Every fitbit counts"
Be sure to visit Fitbit help if more help is needed.
08-04-2017 15:08
08-04-2017 15:08
This worked for me. Thanks for the tip!
08-04-2017 16:27
08-04-2017 16:27
Best Answer08-04-2017 16:29 - last edited on 03-02-2020 16:52 by LiliyaFitbit
"Seamlessly" lol...
08-07-2017 16:58
08-07-2017 16:58
Mine just stopped working, straight after an app update which they say is unrelated but I bet they also released an update on my scales at the same time. I have not been able to connect to my router since, I have wasted hours and hours with no hope, its 3 months old and an expensive item that is no use.
Best Answer08-07-2017 19:11 - edited 08-07-2017 19:11
You might try starting all over @Capio78 since you've already tried everything else. Reset your modem and walk through the Aria setup like it is day 1, this way if you suspect it was an incomplete update you will be able to strike it from your list as a possibility before contacting customer service...
What I would do if everything halted all-of-a-sudden for me, WiFi routers can get confused too.
Let me know how it goes.
WmChapman | TX
08-07-2017 20:33
08-07-2017 20:33
Also, Be aware that the scale does NOT support 5G networks.
08-08-2017 00:34
08-08-2017 00:34
08-08-2017 04:32
08-08-2017 04:32
Wow, busy household @Capio78, looks like your Aria found a quiet channel yesterday. Don't forget (in theory) you have 11 channels available, neighbors could be stepping on a couple as well. I never would have thought to ask how many devices, thanks for sharing.
http://www.metageek.com/training/resources/why-channels-1-6-11.html
Didn't mean to give the impression I was blaming anything, just trying to save you hours+
Thought of a second router?
WmChapman | TX
08-09-2017 05:33
08-09-2017 05:33
I have comcast - My problem was this:
The scale would "say" connect to xfinity wifi - I'd say yes.
I was wrong - I had to wait until my "home" wifi name was showing and connect to it.
Of course I had to disconnect from xfinity (briefly hold bottom corners) before I could connect to my home wifi....
For whatever reason my "home" wifi disappeared during set up and I had to call comcast to "get it back"
Best Answer08-09-2017 06:28
08-09-2017 06:28
Great detective work Kathie, some of those wifi setups can be tricky for sure, why always best to monitor the wifi (with a background settings screen) to see that the connected wifi is truly the "right" one before confirming the connect - computers usually go for the strongest signal when switching around rather than the one you actually may want. When you can confirm you are on the home network, that's the time to confirm you are in set up. Great stick-to-it-tive-ness, well done! Stick around and help other folks with their first time experiences, soooo glad you are here with us.
WmChapman | TX
08-09-2017 09:04
08-09-2017 09:04
That will be a dynamic ip address issue I imagine. Mine connected then d/c again then connected and d/c again without me touching it.
Feel like throwing it in the bin. I had been singing fitbits praises saying what a great product it is, blah blah but it has way too many problems and they'll never replace them. The initial charge 2 I bought was faulty I had weeks of boring emails back and forth until I got annoyed and demanded a replacement at the shop, even the shop advised fitbit don't like to replace they prefer to deal with things but I insisted. I suspect I will need to do the same with my aria.
Best Answer08-09-2017 12:44
08-09-2017 12:44
08-10-2017 09:18
08-10-2017 09:18
I am on my 3rd Aria Scale, and the same thing happens. (was originally connected and then one day just stopped connecting to WIFI).
I go through the setup process then I get a WIFI ERR. Won't connect or sync to my network.
On an Xfinity ARRIS TG1682G Router.
Made sure my router is 802.11 b/g/n.
Made sure the wifi password and network name is correct.
Literally logged into my gateway to verify all of the information, tried setting up well over 20 times to set up the scale. Worked with fitbit support and still can't get the scale connected to the network (when it was in fact originally working on the exact same network with no changes to it previously).
08-10-2017 10:35
08-10-2017 10:35
@Jeffb0572 did you make sure just letters and numbers (no special characters) in that password?
(just thinking out loud)
WmChapman | TX
08-10-2017 10:50
08-10-2017 10:50
Yes, only letters and numbers are in the password.
Again, it worked. Was set up. Worked fine. No issues. Then one day, just stopped synching and won't connect to wifi any longer.
Makes no sense since it was working before.
no changes were made to the network or hardware.
Best Answer08-11-2017 13:24 - edited 08-11-2017 13:25
Their returns policy is a joke, they just stop responding to emails once they have exhausted their options and it is obvious it is a problem with the unit. 5 days without a reply now. Monday I'm taking it back to the store I brought it from and asking for a refund. I now have a situation where it sometimes syncs, it sometime doesn't, whenever it does it takes an age and say it doesn't on the scales but often actually does and half of the time my body fat never makes it past the sync.
Best Answer08-15-2017 20:16
08-15-2017 20:16
Mine will not see my home wifi after it tells me to go back to it after hooking up to the scales connection. No matter what I try. It won't let me enter it, yes I'm using the correct wifi and pw, and get an error every time. This should not be so **ahem** difficult. This is very frustrating.
