04-23-2017
05:28
06:17
JuanJoFitbit
04-23-2017
05:28
06:17
JuanJoFitbit
Hi!
Another Aria that dies after a battery change. Worked fine and i got a message "Your Aria battery level is low". Changed the batteries and know it woun´t start up. Completely dark. Tried to take out batteries for 10 sek and put them back in again but no luck.
I have send an email to support. Hope they could help me.
It seems that this is a common problem, anyone that know what to do.
Moderator edit: format
04-24-2017 13:22
04-24-2017 13:22
Hi
I left the batterys out over night and then put them in again. I notised that the plus pol on the battery didn't connect good.
Did a little bending to get better contact and now the Aria is up and running again.
Skickat från min iPhone
04-23-2017 05:43
04-23-2017 05:43
Hi
Ok i sent you an email
04-23-2017 15:40
04-23-2017 15:40
I also have dead scale after changing batteries. Did you figure out what is wrong?
Best Answer04-24-2017 06:47
04-24-2017 06:47
Mine just did the same thing today. Any answers yet?
Best Answer04-24-2017 13:22
04-24-2017 13:22
Hi
04-25-2017 04:28
04-25-2017 04:28
04-25-2017 04:28
04-25-2017 04:28
04-25-2017 07:49
04-25-2017 07:49
@Kpeson @Cindih77 It's great to have you both aboard in our Fitbit Community! I'm so glad to hear that your Aria scales are working properly now. Thanks for keeping the update here.
@ksdw Thanks for joining us in this thread and our Fitbit Community! Please try @Kpeson's tips. Sometimes the contacts may move a little bit. Also, clean the contacts. where the batteries are placed, with a cotton swab and a little bit of alcohol. After this put the batteries back in and see if your Aria's display turns on.
See you guys later! ![]()
05-30-2017 20:21
05-30-2017 20:21
Same thing happened to me. I will continue to take batteries in and out play with my Aria scale a bit more but its completely black still. My fit bit around the wrist broke off and fell somewhere so I wasnt so much in a hurry because I cant find the fit bit due to the band breaking. Second fit bit this has happened to. Fingers crossed.
06-01-2017 08:14
06-01-2017 08:14
Update' called customer service and the gentleman there was very helpful. He guided me through setting it up again and having me take in and out several times batteries out (although those were New out of package batteries) he had me open a fresh pack. 15 min later I'm back up and running. Lesson for me is... call in and try everything. I was just about to throw my scale away and instead returned batteries that were faulty. A lot to go through but I love this scale.
06-02-2017 15:49
06-02-2017 15:49
Please help, what battery type do our Aria scales use?
Best Answer06-03-2017 04:56
06-03-2017 04:56
@skinnyrie It's great to see you in our Fitbit Community and it's also great news that your Aria scale is working as it should now. I'm glad to hear that our Support team helped you to get this issue resolved.
@Beezy1978 Thanks for participating in this thread! Regarding your question, the Aria scale uses 4 AA batteries. The brand, it doesn't matter.
Keep me posted if more questions arise my friends! ![]()
10-22-2017 15:54
10-22-2017 15:54
I did the bend thing, didn't change anything. change from putting in the new enrgizer ultimate lithium batteries to some previously used duracell copper tops and things started working normally.
10-23-2017 06:33
10-23-2017 06:33
Welcome aboard @bajascoob! Sounds pretty odd that the used batteries brought your Aria scale back to business. However, I'm glad to hear that it's working properly now. Thanks for posting the update here.
I'd like to invite you to visit our Discussions board where you can share your experiences, meet people and create new topics.
Hope to see you in our Fitbit Community more often my friend! ![]()
11-08-2017 04:05
11-08-2017 04:05
Love this forum. Had the low battery warning, changed to new batteries and scale dead! Immediately went here and tried solution and I'm up and running... go Fitbit!!
11-08-2017 05:01
11-08-2017 05:01
I switched from Duracell to Energizer and Walla! It worked. Crazy process, but now I know!
Best Answer11-08-2017 05:02
11-08-2017 05:02
I had to switch from Duracvell to Energizer and it fixed the issue immediately. No other changes.
Best Answer11-08-2017 05:03
11-08-2017 05:03
I was using Duracell batteries and swapped them to Energizer. That fixed the problem. Doesn't make any sense, but it worked!
Best Answer11-14-2017 04:28
11-14-2017 04:28
@Tennisgirl1 @ShadeauMasterJo I'm so glad to hear that your Aria scales are working properly now. Thanks for sharing the workarounds that helped you to get the issue sorted out.
I'd like to invite you guys to visit our Discussions board where you can share your experiences, meet people and create new topics.
Hope to see you both in our Fitbit Community more often my friends! ![]()
Best Answer01-13-2018 18:00
01-13-2018 18:00
So what happens if you get the low battery issue when you first get the Aria scale, and new batteries nor cleaning the contacts works? Ive tried everything, received it as a gift and it' a paperweight so far.
