11-09-2019
22:36
04:52
LanuzaFitbit
11-09-2019
22:36
04:52
LanuzaFitbit
Aria scales stopped working for no apparent reason. After I step on scales:
SENSING
STEP OFF (I step off)
THINKING
ERR
Tried removing the batteries. Same outcome.
What should I do next ?
Moderator edit: Labels
11-10-2019 15:07
11-10-2019 15:07
I have the same problem.
11-11-2019 04:55
11-11-2019 04:55
Yes mine is the same
11-12-2019 21:09 - edited 11-12-2019 21:54
For my Aria 1 this exact same thing happened. This indicates an electrical problem inside the scale. I found a YouTube video of some guy that opened his, found a pinched wire, repaired it, and got it working again. When I opened mine, one of the plastic housings on the four corner weight sensors was broken and thus messed up the weight and/or body fat measurements. I tried re-glueing and stiffening the plastic housing, but to no avail. Since the scale was nearing 4 years old, I bought a new Aria Air. It was half the price of the Aria 2, but you do have to have the app open and click "Save" every time you take a weight measurement. No body fat % either, only calculated BMI.
11-13-2019 01:29
11-13-2019 01:29
My batteries had got drained, but I didn't replace them for a few weeks, but today upon replacing them I'm getting exactly the same error message as described by the OP in this thread. This makes me wonder if it's some software issue.
11-13-2019 02:48
11-13-2019 02:48
11-13-2019 21:40
11-13-2019 21:40
Having same issue! Tried to remove batteries a few times, no change/no luck. Anyone have any resolution?
