04-17-2015
09:32
14:53
04-17-2015
09:32
14:53
My Aria runs almost all the time and won't turn off. It switches between different messages such as "please step on" to "sensing" and others when no one is in the room. It does occasionally stop but not for long. It eventually wears its batteries down doing this within a few days.
I've tried cleaning off the deck and obviously changing batteries but I'm at the point of just throwing the thing out.
Is there anything else I can do?
10-20-2021 13:29
10-20-2021 13:29
I am having this exact issue. My Aria worked fine for ages but now it's going to be going through batteries so fast it won't be worth it. I see no real solutions in the comments. I can remove the batteries after each weigh in (ugh!) or I can transfer it to a soft surface for storage (more ugh!). I contacted customer service through a direct message and received silence in response. All things Fitbit have gone downhill since they were bought out. I might just finally be ready to move on to a different brand entirely.
10-20-2021 14:19
10-20-2021 14:19
10-20-2021 14:40
10-20-2021 14:40
I had the same problem. The solution is to take it off of the flat level surface for a while. I lean mine against the wall when it does this and it works every time.
10-21-2021 06:07
10-21-2021 06:07
As a number of us have mentioned, it sometimes works to stand it on its side ( this works for me ) or store it upside down when not using it. One person mentioned storing it on blankets or something soft .
The issue is the transducer ( strain gauge? ) has developed a set or an offset such that is on the edge of being ON. The Aria has no ON switch so there is circuit to sense if someone has stepped on . This part is confused.
So by turning unit upside down or on the side the sense circuit is below the ON threshold.
Note this is just a guess !!
But works for me.
