Aria incorrectly thinks I'm a Guest - How to fix?
I've been on holiday and put on some weight (as you do) to the point my Aria scale isn't recognising me as a user but as a guest.
No big deal I thought, has happened before, I can just go into the recent weigh ins and assign the weigh in to myself. Apparently not. 🙂
It appears Fitbit have removed that option from the app and website (I've seen the locked thread). So my question is "What now?". Is my Aria scale now for the bin as it's become useless, it'll never add to the app or website and will never show me bodyfat (meaning I cant even manually add in the app) as it doesn't do that for guests?
Is there a workaround that anyone has found (as it seems Fitbit wont fix this, that other thread has been outstanding for quite some time, has been locked and has no fix)?
1 REPLY 1
Hi, @gaz_5_m! I noticed this, too, it's a nuisance. Have you tried just logging your weight manually in the app? Theoretically, the scale will be looking for you to have a weight similar to your last one, so if you can have it already have a weight to match up to, it might start recognizing you again.
MakMak | Community Council
