11-24-2020
11:00
07:21
JuanJoFitbit
11-24-2020
11:00
07:21
JuanJoFitbit
So I have an Aria and it was working fire for a week or so. I just noticed it wasnt logging any of my new weight and realized it wasnt connected to Wifi. I tried connecting and it failed. Most of the forum suggested I try a 2.4 ghz - 802.11 b/g/n which I did and it still didnt connect. I even reached out to Xfinity and even they couldnt see any problem. Any one knows how to fix this?
Moderator edit: format
11-25-2020 03:57
11-25-2020 03:57
Even though you’re on the 2.4ghz of your router, you have to make sure the bandwidth is 20mhz and set the actual channel to like 6 so it won’t auto change
