04-04-2020
08:39
07:10
JuanJoFitbit
04-04-2020
08:39
07:10
JuanJoFitbit
Have read lots of posts about this going back to 2017. Fitbit - what are you doing about this? My scales stopped working yesterday when I changed the batteries.
04-18-2020 05:15
04-18-2020 05:15
I keep getting thinking err message. Since I changed the batteries. It's been going on for months so I haven't used the scale. Want to use it. Can this be fixed or do I need to get a different make and model scale?
04-13-2020 08:34
04-13-2020 08:34
Hi @Frizby,
There's several codes for various ERR messages, which one specifically do you keep getting?
one cruise ship at a time!04-13-2020 09:45
04-13-2020 09:45
04-18-2020 05:15
04-18-2020 05:15
04-18-2020 16:00
04-18-2020 16:00
Silence from fitbit on this issue.
I did the same, changed batteries, connected to my new router successfully. Then when I tried the scale, step off, thinking ,ERR.
Piece of crap is going in the bin and I will be buying a new scale from somebody else
04-21-2020 09:55
04-21-2020 09:55
I am of the impression that it is software related. It seems to have started with the last software update. My Aria (original) won’t quit randomly giving the step on, step off, thinking, and ERR messages. Going through batteries like mad
04-21-2020 10:01
04-21-2020 10:01
Youre probably correct when I talked with them they were pretty much saying buy their new model. I have another scale same model in storage when I get it I will post if it works. It would be good to know if it writes to a log file we can look at...
Too bad Ive lost confidence in ALL fitbit products...
I now own a Samsung Frontier Watch works GREAT!!!!
I have the Blaze guess I will give it away it works OK but I had problems with the GPS connecting to my phone which they fixed with a new model this company support really sucks!!
It it owned by Google now?
04-21-2020 10:03
04-21-2020 10:03
It just says thinking then ERR no codes at all
04-22-2020 05:36
04-22-2020 05:36
Is have received the same message ERR.
Fitbit say it's out of the two year warranty after doing everything stated by them and reconnecting the device back to the WiFi.
Fitbit said it connected 15hrs ago but unable to answer me what it was doing connecting to Fitbit but not weigh me?
Very strange goings on.
05-14-2022 16:31 - edited 05-14-2022 16:31
my aria did the exact same thing........going thru batteries like crazy...now i cant connect to wifi...just get ERR message.....did you ever get it to work???
