12-18-2023 07:53
12-18-2023 07:53
I have the original Aria, the 4 AA battery scale. It showed weight through last month. Now after stepping on the scale it says "sensing" then "step off" then "thinking" then "ERR". I tried removing the batteries for about a half hour but that didn't do anything. I can't find a reset button anywhere. Anyone know how to resolve this? Thanks for any and all constructive input.
Best Answer12-30-2023 09:28
12-30-2023 09:28
I have the exact same issue 😢 Has anyone figured out how to fix?
Best Answer01-01-2024 09:08
01-01-2024 09:08
I am having the same issue, I would like for someone to assist with this.
Best Answer01-12-2024 07:43
01-12-2024 07:43
Same issue here. Trying a reset and a reconnect to wifi did not word either. What a mess.
Best Answer01-13-2024 00:23
01-13-2024 00:23
Same same here. Tried all that you folks have tried & still same issue. I cannot get mine connected to the wifi, so it seems that as these are the older version, they may not be compatible as no update is available.
Unless a solution is made known to us all very soon, I will be giving up and buy the Garmin smart scale (I now use a Garmin watch).
Thanks & good luck all.
