02-08-2019
21:19
08:45
02-08-2019
21:19
08:45
After about 2 frustrating years with the Aria, I'm going to throw it in the bin because of its inconsistent weight readings. I can get the same inconsistency from a $10.00 set of scales.
I also find the advice from fitbit so annoying. Their advice is basically, 'Have you tried turning it off and on?'
I had to stand on the Aria seven times today to get two readings that were the same. The difference between the smallest and largest weight was 900 grams (2 pounds).
Fitbit, when you make Aria 3, spend all of your R&D budget on making a scale that weighs consistently.
02-09-2019 08:33
02-09-2019 08:33
@SunsetRunner It's great to see you in our Fitbit Community! I'm sorry about the experience you've had with your Aria scale. I know how frustrating this is for you and I appreciate your feedback and comments since this helps us to keep improving.
