02-09-2017
19:17
14:53
02-09-2017
19:17
14:53
Aria is not showing any weight or body fat on the scale itself but weight shows in fitbit app but not body fat %. How do I get the weight to show on the scale again?
02-11-2017 03:25
02-11-2017 03:25
@Railgirl It's great to have you aboard in the Community! Seems odd that your Aria scale is not showing your readings on the scale itself. Please try taking the batteries out, clean the contacts where the batteries are placed with a cotton swab and a little bit of alcohol. Once this has been done, put the batteries back in and check out if the display shows your readings as it should.
Let me know how it goes my friend! ![]()
Best Answer02-11-2017 04:42
02-11-2017 04:42
JuanJo, whilst your enthusiastic responses are appreciated, giving the same advice to every user, for numerous different issues is wearing a bit thin. This product is junk.
Please Fitbit, acknowledge the product is flawed and take it off the market! Don't leave it to your community mods to try to brush under the carpet.
02-13-2017 04:46
02-13-2017 04:46
@Stu_P Thanks for participating in this thread! I would like to help you and turn the bad experience you've had into a good experience. Please provide more details about the issue you are experiencing with your Aria scale and I'll be happy to assist you.
Looking forward to your reply! ![]()
Best Answer03-13-2019 23:30
03-13-2019 23:30
I’m having the same issue and have done what you advised. Was there a resolve to this?
i have also set up the scale again to resume syncing.
thanks!
Best Answer03-16-2019 05:48
03-16-2019 05:48
@SunsetRunner I'm sorry for the late response. However, I would like to follow up on the issue that you are experiencing with your Aria scale. I appreciate the time you took in trying the troubleshooting steps provided previously.
I'd like you to try one more workaround if you haven't done so: Please restart and re-calibrate your scale by taking out the batteries for 15 seconds and put them back in. After this, weigh yourself 5 consecutive times and see if your scale provides accurate readings.
Keep me posted on the outcome! ![]()
