Aria original won’t connect to new wifi
We have a new wifi and I am not able to get my original aria scale to update. The “setup active” does not display, but it does show the former wifi name and display “tap to change”. I tap the two bottom corners of the scale and nothing happens. Then the screen turns off.
i have updated wifi before, and had no issues. Is there something that I’m missing?
3 REPLIES 3
Hello @laurelkperk
I found this article that might help you through the process: https://blog.rottenwifi.com/fitbit-aria-change-wifi/
😃 Please let me know if this provided you a solution to the issues you’re experiencing setting up your Aria Scale to a new Wi-Fi
This is the article that I followed, but I didn’t go to the very bottom paragraphs. I will try again
Thank you for your suggestion.
Sent from my iPad
😉 let me know how it goes
