06-29-2017
23:22
14:53
06-29-2017
23:22
14:53
Do not buy the scale. The digital
display has fades after 12 months. Buyer beware.
07-02-2017 13:16
07-02-2017 13:16
Are the batteries fully charged? That sounds about the life expectancy of the battwries to me. Complain to customer service maybe they can fix it!
07-02-2017 18:23
07-02-2017 18:23
What she said 🙂
The batteries that came with it, won't last much more than a few months.
Best Answer03-21-2018 11:42
03-21-2018 11:42
My response:
Best Answer03-22-2018 05:32
03-22-2018 05:32
@Caribwm It's great to see you in our Fitbit Community! I'm sorry to hear that your Aria's display won't turn on. I'll be glad to help you and find a solution for this issue. Please take out the batteries, clean the contacts or springs of your scale with a cotton swab and a little bit of alcohol. Once this has been done, put a new set of batteries (make sure that the're not rechargeable). Once this has been done, check out if the display turns on as it should.
@MissAli @AZToast Thanks a lot for your help and contribution my friends!
@Goelsewhere I'm sorry to hear that your Aria scale stopped working as well and it's no longer under warranty. The warranty is good for 365 days. I really understand your frustration and how you feel about this. Thank you for your feedback and comments also and I'll forward this info to our team since this helps us to keep improving.
See you all later! ![]()
Best Answer07-11-2019 23:46
07-11-2019 23:46
I have the same case, The LCD screen has faded or not visible anymore. I have a new batteries and thought I could hard reset this thing but no luck. This is clearly and should have been a recall on this Aria Product line.
Best Answer07-23-2020 00:24
07-23-2020 00:24
Same problem happened to me, replace the batteries and realised if you shine a light through the led display that the led display works but the backlight stopped working so you can not see the display. Reported this to Fitbit and they acknowledged the problem but nothing came of it as the product was out of warranty.
