03-07-2019
17:16
14:53
03-07-2019
17:16
14:53
Hello
please help to understand why Aria Scale doesn’t turn on when I step on it.
08-23-2020 20:57
08-23-2020 20:57
I am encountering the same issue. I tried to do the cotton swab thing it didn't work. I have replaced he batteries twice. Does anyone have any advice?
08-24-2020 08:58 - last edited on 08-26-2020 20:05 by LiliyaFitbit
I actually gave up and ordered a new scale. So sad they do not refurbish the old ones as ours looked quite new and it was the second one we had to trash. i think the technology is not there yet. Im hoping with our third scale it is as I like the concept although I am afraid to change the batteries. Ours just quit after we changed the wifi. 😞
08-29-2020 19:43
08-29-2020 19:43
Very disappointing that Fitbit is not giving better answers to this “common” issue. I’ve had this issue over the years when changing batteries with this scale. It reminds me of the old PCs with build in CMOS and it OK until it looses charge then your out of luck and replacing a whole unit. I feel that unless Fitbit acknowledges this issue then why would I buy a replacement for it. Time to look for alternative options.
08-30-2020 07:45
08-30-2020 07:45
Same as all of you.
I try to replace the batteries ... Was needed.
New batteries ... And .... The symbol " ! " Then turn off and never turn on again.
Tried the reinitialisation: the process goes ... Then again " ! " And off and still this alway off ...
The scale is less than 2 years old!
He to find a solution soon
04-22-2022 07:33
04-22-2022 07:33
My scale stopped working as well and it was working just fine. I changed the batteries twice and cleaned the connectors and to no avail. I feel duped. What can I do?
05-10-2022 17:59
05-10-2022 17:59
Same here, but I guess the chances for a resolution after 3 years are slim.
Unfortunate.
05-11-2022 06:08
05-11-2022 06:08
