09-01-2020
13:05
04:25
JuanJoFitbit
09-01-2020
13:05
04:25
JuanJoFitbit
Ive had the Aria scales 1 for several years and all worked no problem.
Over the weekend they started reporting that they were not connected to the Wifi (after a weigh-in the scales showed a wireless icon with an x on the top)
I removed the batteries for 10+ seconds, reinserted and got the "tap to setup" which I did, and setup them again on my wifi (a Unifi AP) which has worked seamlessly for years and couldnt get it to join the wifi, after several attempts it did join (at least they implied that they had) and I weighed in and got the same no wifi icon.
I then plugged back in my BT router and setup a new SSID and joined the scales to that wireless and tried to get weighed but again got an error, either No Sync or I get No Wifi and asked to setup the wifi again.
Do the scales get "firmware" and if so has there been a recent update that could have caused this?
Is there more of a factory reset that I can do other then removing the battery and setting up again?
Any suggestions welcomed
Sput
