02-18-2020
06:24
06:20
JuanJoFitbit
02-18-2020
06:24
06:20
JuanJoFitbit
My scale stopped showing body fat. It showed it for a while now stopped also every time I weigh it makes you step off it use to recognize when you step on and show weight and body fat. I took the batteries out and restarted but it didn’t change.
02-18-2020 08:03
02-18-2020 08:03
Hi @Williams99
Do you have an Aria 2? If so, please refer to the information below.
WHAT DOES ARIA 2 MEASURE?
Each time you weigh yourself with Aria 2, the scale shows your weight. You can choose to have the scale display your body fat percentage and BMI as well.
Body fat percentage is the mass of your fat divided by your total body mass. It's estimated using bioelectrical impedance analysis, which sends a small, safe signal through your body. Generally, a body fat percentage between 10-22% for men and 20-32% for women is considered healthy (source).
BMI is calculated using weight and height to provide a number that categorizes individuals as underweight, normal weight, overweight, or obese. A BMI between 18.5 and 24.9 is considered normal (source).
To adjust whether body fat percentage and BMI are shown on the scale:
, and tap your profile picture.
Please let me know if this helps 😊
02-18-2020
13:02
06:21
JuanJoFitbit
02-18-2020
13:02
06:21
JuanJoFitbit
Yes that was already checked off. It still does not show body fat
I did that. It still does not show body fat percent
Sent from my iPhone
Moderator edit: merged reply
