Aria won't sync with MyFitnessPal
Aria scale used to sync to MyFitnessPal. No longer working for last few days since  I changed batteries. Or since summertime?  Weight is registering on Fitbit. I can’t find any way to add device through Fitbit online but it says it is added in MyFitnessPal.
1 REPLY 1
Hi @snoodlest,
To add the device through Fitbit, you need to go to your "Account Settings" on your Fitbit app and then select "Add New Device".  It should show up as an option there.  Please follow the prompts from there.
If the weight is registering on Fitbit, then the fact that it's not registering on MyFitnessPal is something on the MyFitnessPal end.
one cruise ship at a time!
