10-31-2020
15:28
06:06
JuanJoFitbit
10-31-2020
15:28
06:06
JuanJoFitbit
My Aria runs almost all the time and won't turn off. It switches between different messages such as "please step on" to "sensing" and “thinking” and others when no one is in the room. It does occasionally stop but not for long. It eventually wears its batteries down doing this within a few days.
I've tried cleaning off the deck and changing batteries but can’t keep putting in new batteries every few days.
Is there anything I can do to fix the problem with my Aria? It was gifted to me as a birthday present in 2014. I really like it but this issue is frustrating me. Please help.
Moderator edit: updated label
11-06-2020 09:23
11-06-2020 09:23
Same annoying problem...is there a way to put aria to sleep?
Replacing batteries every 1-2 weeks.....
11-06-2020 18:49
11-07-2020 13:09
11-07-2020 13:09
Also having this issue
11-11-2020 06:27
11-11-2020 06:27
I am ready to put this in the trash. I am spending more money on batteries. I like the look of the scale. Can you disable wifi and just use this as an old fashion scale
11-13-2020 14:55
11-13-2020 14:55
Exact same problem for me. Unfortunately Fitbit doesn’t seem to have a solution...
Best Answer11-17-2020 06:22
11-17-2020 06:22
Have you been able to fix the problem? If so please let me have the solution
Best Answer11-17-2020 07:54 - last edited on 12-16-2020 19:12 by LiliyaFitbit
No...bought a weight watchers scale...now upload data manually. Stupid Aria!
Best Answer02-14-2021 12:04
02-14-2021 12:04
Yep, my scales exactly the same - would like to hear something from Fitbit but they dont care about their older customers. I've had other issues in the past and they just dont respond, or respond very slowly. I would be tempted to upgrade to a later version if they had a valid reason for why the original version has clapped out after 3-4 years - but there's just no way to get an answer from them!! Time to try Xiaomi, I think...
02-15-2021 09:33
02-15-2021 09:33
I have the same issue.
The problem is that the 4 foot pads are sensors that have the turn on switch integrated into them and use the plastic structure as the return spring and in my case 2 of them are broken.
I replaced the scale with the Air , WHAT A MISTAKE that is, don't do it not worth the hassle
Best Answer02-16-2021 02:30
02-16-2021 02:30
Best Answer02-16-2021 03:44
02-16-2021 03:44
