01-07-2018
20:57
08:45
01-07-2018
20:57
08:45
Just purchased Aria2 to go along with my new tracker. Trying to setup the device using the iOS app (updated to the latest version). Aria2 won't accept the password for the wifi. A google search shows this is a pervasive problem. This is embarrassing. First, why does the scale even require a wifi setup? if it can connect to a smartphone (and hence the app) via bluetooth that should be all that's required. Second, when will fitbit officially acknowledge the problem, offer a fix or recall the product altogether? I'll probably return the scale (and maybe even the tracker), which is a shame and a waste of my time.
11-19-2018 08:17
11-19-2018 08:17
@mcg123 Your feedback is appreciated. I understand that my responses have been repetitive. However, I'll be happy to do my best and assist you if you need help.
12-30-2018 11:45
12-30-2018 11:45
Have the RT-AC1200 as well with the exact same problem. Were you able to resolve it with that router or did you have to get a new one?
12-31-2018 07:16
12-31-2018 07:16
@blockpardi Welcome to our Fitbit Community! I'm sorry to hear that your Aria 2 is not connecting to your RT-AC1200 router. I'd like you to make sure that your router complies with the following settings:
These settings can be verified with your Internet service provider.
After this, try the setup process as described in this help article.
Let me know how it goes!
12-31-2018 14:51
12-31-2018 14:51
12-31-2018 18:29
12-31-2018 18:29
Well, I tried all those "standard" fixes, several times actually and including resetting the scale. Nothing worked. But something Shwalamazula said got me curious. The RT-AC1200 is dual band, and I wondered if that was screwing things up with the scale (it shouldn't by the way, but it clearly wasn't working like it should.) So what I did was, leaving everything else the same, I made sure each band used different frequency ranges. For 2.5 GHz I set it to 20/40 MHz.
And for 5GHz I set it to 80MHz.
That seems to have did the trick. Been working for over a day now. I'll keep an eye on it and report back if anything changes.
Seems like a software problem. Not good, but hopefully Fitbit can find a fix.
01-02-2019 03:33
01-02-2019 03:33
@Shwalamazula @blockpardi I'm so glad to hear that you guys managed to get this issue resolved and your scales are working properly now. Thank you for posting the update here and sharing the steps you guys followed. I'm sure that this will help other users that experience the same issue.
I'd like to invite you guys to visit our Discussions board where you can share your experiences, meet people and create new topics.
Hope to see you both in our Fitbit Community more often!
01-02-2019 22:24
01-02-2019 22:24
01-05-2019 06:56
01-05-2019 06:56
@Shwalamazula I appreciate your contribution and your feedback. Regarding your request, I'll send your case to our Support team and they will provide more information if this can be done.
Let me know if you need further assistance.
01-05-2019 07:28
01-05-2019 07:28
We have an Aria scale and have wasted so much of our personal time trying to get the Aria scale to connect to networks. It is amazing how simple it is to use fitbits and how difficult it is to use Aria scales.
We have an Aria that we bring back and forth between our two homes. We have used it for a couple of years and always have had issues trying to get it to connect to the network at either of the houses. After about an hour and calls to fitbit, we finally get it done.
Unfortunately we have now struck out on today's 90 minutes attempt. It appears a change was made where our 2.4 ghz network password will no longer be accepted because it is all numeric characters. This is the same network / router / password that worked just 9 months ago in March 2018, but the Aria will no longer connect to it and gets a wifi error.
Can fitbit make these Arias any more difficult to work with????
01-05-2019 10:56
01-05-2019 10:56
I found out it was a setting in my wifi network set up.
01-08-2019 03:48
01-08-2019 03:48
@West57 Thank you for participating in our Fitbit Community! I'm sorry about the time you've spent trying to get your Aria scale connected. Please let me know what is the model of your Aria scale. You can see the differences listed in this post. Also, let me know what is the make and model of your router. This info will help me to assist you accordingly.
@cindysalon Welcome to our Fitbit Community! In order to avoid any misunderstanding on my end, I would like to follow up and would like to know if your Aria is working properly now.
See you both later!
01-08-2019 13:07
01-08-2019 13:07
01-09-2019 16:21
01-09-2019 16:21
Well, I'm back to square one. Worked for a few days then suddenly it didn't. Now I can't get the scale to connect no matter what I do. Very very frustrating.
01-14-2019 07:46
01-14-2019 07:46
@West57 Thank you for letting us know the make and model of your router. Our team is aware of this and are looking into this with Xfinity routers. Once a solution is available, we'll make sure to post it in the Community. I truly understand how frustrating this is and I appreciate your feedback since this helps us to keep improving.
@blockpardi Since the issue persists, let me go ahead and forward your case to our case to our Customer Service department and they'll be happy to follow up. You will receive an email soon.
I'll be around if more assistance is needed!
01-14-2019 08:49
01-14-2019 08:49
So I determined it was my wireless access point that was causing the problem. For some reason the Aria doesn't like it (it's an ASUS RT-AC1200). So what I did was get a cheap range extender like this one, and that seems to have solved it. Connected immediately and been working flawlessly ever since. Not great that I needed more hardware, but a ~$30 fix was better than having to replace the router.
01-15-2019 05:31
01-15-2019 05:31
@blockpardi I'm so glad to hear that you managed to get your Aria 2 set up using an extender. Thank you for posting the update here and sharing the steps taken.
I'd like to invite you to visit our Discussions board where you can share your experiences, meet people and create new topics.
Hope to see you in our Fitbit Community more often!
04-29-2019
21:49
04:40
JuanJoFitbit
04-29-2019
21:49
04:40
JuanJoFitbit
Kate,
You keep saying the same things over and over and over again. We are here looking for a fix to why our scale wont accept our password. We have tried everything but bounce on our head and spit nicklea and the set up stills says our password is wrong. Is there, or is there not a fix to this problem?
Have you tried banging your head against the wall, because that is my next option!. Pricey scale that doesn't work.... yay
Every single person before this post has said the same thing.
You haven't assisted anyone or fixed the problem...
How many months does one have to have a problem before someone can get the actual solution.... asking for a friend
Moderator edit: merged replies
05-01-2019 04:51
05-01-2019 04:51
@Fedupwithf-tb-t Welcome to our Fitbit Community! I'm sorry for the late response and I'm sorry to hear that your Aria 2 doesn't accept your password. Please make sure that your WiFi password doesn't have more than 31 characters.
Please provide a screenshot of the page that is telling you that the password is wrong (You can find the instructions to add your screenshot to your posts here) This information will help me to determine the cause of the issue.
In the meantime, check out and make sure that you are following the setup instructions as described in this help article.
Keep me posted!
05-01-2019 21:26
05-01-2019 21:26
05-02-2019 05:11
05-02-2019 05:11
@Shwalamazula Thank you for joining us in this thread! I appreciate your feedback.
I'd like to follow up and would like to know if you are experiencing the same issue.
