12-05-2023 08:03
12-05-2023 08:03
Aria2 is synched to Fitbit but does not show on my fitbit6
12-05-2023 09:20
12-05-2023 09:20
I expect by fitbit6 you mean Charge 6. But in any case, I don't think the scale, or even weight, ever shows on your wrist, only on phone fitbit app.
12-05-2023 09:44
12-05-2023 09:44
12-05-2023 09:45
12-05-2023 09:45
Yes I mean the charger 6. It does not show in the Fitbit app on my phone.
12-05-2023 11:43
12-05-2023 11:43
Assuming you have the newer version of the Fitbit app, the place you would see it is:
From Today tab, tap the symbol at top left that takes you to "Connected to Fitbit" screen. You should see it there. If not, I wonder what you mean by it being synced to Fitbit. Did you add the Aria 2 to Fitbit? If not, on the bottom of that screen, tap "Add more devices". It asks "What are you setting up?" Select Aria 2, and proceed.
12-10-2023 14:53
12-10-2023 14:53
12-10-2023 19:05
12-10-2023 19:05
So the Aria 2 does show in the phone app but your weight does not show. Right?
It could be a problem with your scale's connection to your wifi network. After you weigh yourself, does the scale display and error message or code, or does it display your weight and eventually a check mark indicating it completed synching to to the fitbit server successfully? Did you make any change to your wifi or to the location of your scale after the last time you got a good reading?
Hold on. Are you sure you have Aria 2, not Aria Air? I just realized you said your bluetooth is connected. I don't think the Aria 2 even has a bluetooth connection. Aria Air and Aria 2 are not the same thing.
