01-03-2023
14:34
16:08
LizzyFitbit
01-03-2023
14:34
16:08
LizzyFitbit
The Aria Air scale is able to automatically log your weight in Fitbit app for users with iPhone without problem. Many Android users though need to force quit their Fitbit app to get the weight to feature to kick in after being away from the scale when getting home.
01-06-2023 06:13
01-06-2023 06:13
At the very least it should be advertised that this only syncs to iPhone as described because noone wants to reconnect the scale every time they use it. I just bought it and am greatly disappointed.
01-07-2023 03:00
01-07-2023 03:00
I´ve been i contact with support so many times regarding this scale and sync issues. This post that you have replied to is actually created by a Fitbit administrator based on text i used for creating a "feature request" for the development team to acknowledge this as a serious problem. Feature requests are posted here and is not part of the forum threads. What the administrator did was simply to cancel my feature request and create a new post among all the other similar ones.
It seems to me that this scale has serious issues and sometimes works and sometime not. It mostly works for iPhone users but It happens to them as well (I have both Android and iPhone and have tested with mixed results on both) but not that often. If it´s the scale, bluetooth, android or iphones is hard to tell. The only thing we as users gets are standard answers like "try reset your scale, read this article bla bla bla).
Instead of writing in this post. Go here.
01-07-2023 13:12
01-07-2023 13:12
Reply from support January 7th 2023
Thanks. We verified that this is a known issue, and we're currently working to resolve this issue and hope to have a fix soon. In the meantime, we recommend keeping your Fitbit device and app up-to-date. Thanks for your patience while we work to get you back on track, and let us know if you have any other questions.
----end quote
Does anyone know for how long this has been an issue?
Hopefully the Dev team will fix this. Let's hope for the best.
01-10-2023 01:44
01-10-2023 01:44
Quick bit of info that may help (I'm going to post this to the other topics concerned with sync issues) - I recently purchased a FitBit and the Aria Air - initially I kept getting intermittent connects, suffering the same kind of issues stated in this thread and had to go through the steps described elsewhere for resolution (basically a full re-install). However, I've found that, in my case, just going to "Today" on the phone app before stepping on the scales isn't enough - you have to also go into the "weight" tile (where it has a pic stating "Sync your Weight" and "Step onto Aria Air to get started") and THEN it works when you step on the scale and has worked consistently for me over 3 weeks of testing.
Hope that helps, if I made you smile today its been a good day 🙂
01-14-2023 08:00
01-14-2023 08:00
I've been doing the same thing and it doesn't work. I have to repair it every morning on my android device.
Fitbit, can we please get an update to why your hardware isn't syncing with your software? What is going on?
01-14-2023 13:55
01-14-2023 13:55
Not working unfortunately 😔 Same issue still.
01-14-2023 16:48 - edited 01-14-2023 16:52
I have a Samsung Android and Pixel Watch and just purchased the Aria Air. I have been going to the weight area figuring that's where I should be to sync weight - and it has NOT worked for me except for the first time, which is not in the morning when I usually weight myself. When I tried the next morning it would not sync, so I deleted the scale from my Fitbit app on the phone and tried to sync again and was told I needed to be invited - so I had to reset the scale. Additionally, I invited my husband and he gets an error every time he tries to use the link in the email - I'm not even sure if he is setup properly. Does this scale get confused because of multiple users all with Bluetooth connecting to it? My husband likes it because it looks cool, but I feel like I just wasted $40 since we had a perfectly functional scale before.
01-18-2023 06:45
01-18-2023 06:45
insane not sure why but today the fitbit actually synced without having to resync. it hasn't worked for 4 days in a row but now it randomly has.....
was there an update I missed? let's see if this works tomorrow morning also 🙂
01-18-2023 07:19 - edited 01-23-2023 13:15
**Update #2** Maybe I jinxed it, but since my last update it has NOT been syncing again. Four days now and no connection between the Fitbit app and the scale. Disappointing.
**Update** Three days in a row with the scale syncing to the app since the update that just downloaded on 1/17/2023. Appears it may have been released on 1/4 but my phone just updated it.
Yesterday morning I woke up with my watch not syncing to the Fitbit app and I needed to update the app. I did that first thing when I woke up and left the phone open to the app. I then went and weighed myself in another room. When I came back to my phone to manually enter the weight, it had picked up from the scale. Today I had an update to my watch and again opened the Fitbit app and weighed myself - and it worked a second time. I think the Fitbit app update I just received may have resolved the issue.
01-21-2023 08:43
01-21-2023 08:43
So I can say that it was working for 3 days in a row. However, today the app and the scale are not talking. Nothing has changed either so I'm not sure what went wrong.
03-06-2023 07:34
03-06-2023 07:34
I just got an Aria Air rather than another scale that claimed it worked with the Fitbit app thinking if it's made by Fitbit, it has to work better. Well, I've had the same problem that's identified on this thread - the only way it'll work is to force stop the Fitbit app. The sad part is that I should have looked on this forum before buying it - this has been going on for more than a year!
03-08-2023 00:47
03-08-2023 00:47
03-08-2023 13:59
03-08-2023 13:59
I tried this. No joy. The only thing that has worked for me consistently is force stopping the FitBit app on my phone and then weighing.
03-08-2023 21:01
03-08-2023 21:01
Have you tried clearing the cache after stopping the application?
03-10-2023 08:23 - edited 03-10-2023 08:23
this is a known issue for years now my friends.
At this point Google is the one who manages this and they have shown they don't care about this at the moment. Most likely you will see a huge shift in the way this app works in the coming months since they are removing features and "plan" to add others.
I suggest just getting in the routine of adding the weight yourself and not stress about it, because Google isn't
03-10-2023 15:42
03-10-2023 15:42
I did this yesterday. Of course it worked because of the inclusion of the force stop of the app which I found to work consistently. Without doing these steps, it worked today. So, this appears to have solved the problem. But, since the cache needed to be cleared, does it mean I'll have to do this every once I awhile? I guess time will tell...
03-12-2023 18:49
03-12-2023 18:49
Hello! After stopping the application and clearing the cache, the application works with less failures and relatively tolerably. I really hope that Google will solve all the troubles.
03-12-2023 18:53
03-12-2023 18:53
Hello! I'm glad it helped you for a while. It will be necessary to repeat from time to time, but nevertheless it solves the situation. I hope that soon we will be pleased with updates that will solve all the inconveniences of creating a fitbit company
06-22-2023 13:31
06-22-2023 13:31
Same here
