04-24-2020
07:21
07:06
JuanJoFitbit
04-24-2020
07:21
07:06
JuanJoFitbit
Is it possible to have two Aria scales set up in a single account? If so, how is that done?
04-25-2020 13:48
04-25-2020 13:48
Hi @starmanjb,
If I'm not mistaken, you can have more than one Aria scale on your account, provided they're not the same model. So for instance, you can't have 2 Aria 1s or 2 Aria 2s. However, if you had an Aria 1 and an Aria 2, then they can be tied to the same account.
Just log in and set them up as you would if they were a tracker, except select the appropriate Aria model when the app asks you what Fitbit product you have. Then follow the prompts.
one cruise ship at a time!
