02-05-2017 20:18 - last edited on 09-10-2019 14:53 by MatthewFitbit
Hello.
I am going to buy fit bit aria but some people say it should be connected to home wifi broadband. I i don't have a broadband connection so can i use my mobile hotspot. Thanks.
Aryan.
02-06-2017 02:44
02-05-2017 23:51
02-05-2017 23:51
Well @Fitstar6 it doesnt connect to broadband, it connects to uour WiFi. Your wifi needs to be connected to the internet.
Before younpirchsse your Aria please chevk and make sure that it can connect to your router.
02-06-2017 02:35 - edited 02-06-2017 02:36
I am not understanding what you are saying. I am asking that can I connect my aria to mobile hotspot?
02-06-2017 02:39
02-06-2017 02:39
Sure you can connect the Aria to your mobile Hotspot, this hotspot will become your router. You will need to look at the link i posted to learn how to setup your hotspot so the Aria can comunicate with it.
02-06-2017 02:44
02-06-2017 02:44
Thanks
02-06-2017 06:13
02-06-2017 06:13
@Fitstar6 Thanks for participating in the Community! In addition to the information that my friend @Rich_Laue provided, I would like to share the Aria's manual so you can get familiar with the functions and you can get the most out of it.
I'll be around if more questions arise my friend!
02-22-2017 11:08
02-22-2017 11:08
You can not! Mobile hotspot is just a temp signal, you need a wifi router with 802.11b protocol to set your aria, otherwise you will NOT be able to set it up
02-22-2017 11:38 - edited 01-09-2020 02:10
You can use a mobile hotspot, you just need to make sure that it is turned on when taking a reading of your weight.
Yes the hotspot like any other router needs to be configured with the right protocol. The scale needs to be configured to comunicate with the hotspot.
03-15-2019 07:04
03-15-2019 07:04
I had this issue too. Fought it for days. Had to give up Fixed WiFi and was trying to us iPhone Hot Spot. Failed to sync over and over. The issue was the SSID name. NO SPECIAL CHARACTERS! This includes a space! IPhone will automatically put iPhone name with a space in the name.Rename your iPhone without any character or space and BINGO! Success! There is no reason a 70 year old man should have to learn this. Somebody Fix This! Three years of complaints and nada!!
03-16-2019 04:57
03-16-2019 04:57
@PR6252 Welcome aboard to our Fitbit Community! I really understand how you feel about this.
I also appreciate the information you shared above and your feedback since this helps us to keep improving.
Please don't hesitate to get back if you see anything unusual and I'll be happy to assist you!
03-16-2019 21:44
03-16-2019 21:44
If the company really listened to their customers feedback then you would think that there wouldn't be so many frustrated customers year after year with the same problems and endless run around of solutions that don't really work. I don't see any sign of the "keep improving". How can you prove that you "really understand how we feel about this"?
01-08-2020 22:20
01-08-2020 22:20
Did it work using mobile hotspot?
01-09-2020 05:21
01-09-2020 05:21
Hi!
In the start when I bought the scale it did work but after the first update (and all later updates) I couldn’t get it to work anymore (both iOS and Android phones didn’t work).
After trying it over and over again I decided to donate the scale to someone with a stable WiFi at home.
Tried it again recently, still doesn’t work so I don’t think it will ever work again 😞
01-09-2020 05:22
01-09-2020 05:22
Oh and the ‘no special
character’ thing a previous commenter suggested didn’t work with my phone/my husbands phone/a friends phone.
01-20-2020 15:02 - edited 05-31-2020 07:00
To attach an Aria scale to a phones hotspot will take two phones.
Turn your hotspot on.
Get another phone
Install the Fitbit app
Log into your Fitbit account.
Attach this phone to your phones hotspot and setup the scale.
Log out of the Fitbit app on the borrowed phone.
Before stepping on the scale turn your hotspot on.
05-31-2020 01:29
05-31-2020 01:29
I have the same challenge. Currently considering to buy Fitbit Aria 2 scale but I have no WiFi at home, and must run this scale by my phone hotspot.
Is this issue still stand?
05-31-2020 06:56 - edited 07-25-2020 13:37
See my post directly above yours @Soude .
That is if you can find an Aria 2 or buy the Aria Air which only syncs through the phones bluetooth
01-22-2021 11:09
01-22-2021 11:09
Hi Rich, can you send me the link you mention please?
01-22-2021 11:45
01-22-2021 11:45
I never mentioned a link, I posted the instructions above.
