03-23-2020
17:25
07:17
JuanJoFitbit
03-23-2020
17:25
07:17
JuanJoFitbit
Can I use my Aria 2 offline? I’m tired of trying to get it synced to my wifi.
Moderator edit: updated label
03-24-2020 05:27
03-24-2020 05:27
@Hobnov I suppose you could. When you step off the scale, it will go through its attempt to sync, then you will get the wi-fi not connected error. You can enter the values using the Log Weight function of the app.
Have you contacted Support to figure out why your scale won't connect? I noticed that you never posted anything asking for help here.
Laurie | Maryland
