01-01-2020 18:34
01-01-2020 18:34
I know there have been many posts about this or something similar but no resolution
I changed my WiFi about a month ago and when I try to sync to my aria it doesn’t recognize my WiFi - not even coming up as an option?
I read earlier something similar and it being the router ? How the heck do you change the router if that’s the issue ??
01-04-2020 13:21
01-04-2020 13:21
After weighing yourself @Finkerr what is the error that is displayed?
Let's look at this Fitbit help doc.
How do I reconnect my Fitbit scale to my wireless network?
01-04-2020 14:47
01-04-2020 14:47
Thanks rich. It’s when I try to connect. It doesn’t recognize my wifi network. Doesn’t even come up as a selection. My neighbours all do 🙂
01-04-2020 15:04
01-04-2020 15:04
What version WiFi do you have? 802.11b/g/n 2.4GH
01-04-2020 17:36 - last edited on 01-31-2020 16:14 by LiliyaFitbit
same for me, I have spent all day trying. Any solutions? I have panorama WiFi 300 gb
Moderator edit: format
01-05-2020 12:06 - last edited on 01-31-2020 16:14 by LiliyaFitbit
I do not have the 802.11b. I realize that this is the issue. My provider told me that b is older technology. My question is there any way around it or do I now just have a very expensive scale ?
01-05-2020 23:22
01-05-2020 23:22
Buy a cheap WiFi add on and plug it into your router with a network cable.
01-06-2020 11:44
01-06-2020 11:44
01-06-2020 12:33
01-06-2020 12:33
soooooo spend more money to support the fact that FitBit uses old technology? I didn't ask for this not sure why i should spend more to support it... I appreciate that you are just suggesting it but I am incredibly disappointed that I now just have a very expensive scale
01-06-2020 12:47 - edited 01-06-2020 12:49
I can't answer for Fitbit.
The question was how to get around the issue.
I have a valid answer that works.
Most people I know have several WiFi routers laying around ask a friend. Here is one for $20 just take a network cable and connect to main router.
My router has both types of WiFi, the only thing that connects to the 2.4 is the Versa 2
01-06-2020 12:50
